Author Topic: 1988 2.4L Mercury 200hp - which manual?  (Read 1120 times)
April 14, 2008, 12:18:30 AM
Read 1120 times
Hardwater
« on: April 14, 2008, 12:18:30 AM »
It looks like the motor will be going in the shop the end of this week to be checked out - the last step in closing the deal.  Assuming the best, one of the first buys will be a maintenance/repair manual.
I've had manuals for different motors from Clymer and Seloc in the past - each seemed to have their strong points and weak points.  Anyone have experience with either/both of these manuals (or some other source) for this specific motor - any recommendation?  Or is it best to just bite the bullet and buy the Mercury shop manual?
Thanks - Dave.
\'86 222 CCP
\'88 Mercury 200hp Black Max
April 14, 2008, 05:49:47 AM
« Reply #1 on: April 14, 2008, 05:49:47 AM »
If you want the best - buy the merc manual. At least it was written by the factory.  The Clymers I have leave just the stuff you really need OUT.
April 14, 2008, 09:05:18 AM
Manuals
« Reply #2 on: April 14, 2008, 09:05:18 AM »
I am a fan of the Seloc manuals.  In fact, some factory manuals are actually prepared and printed by Seloc.
The problem with some factory manuals is they require/expect you to have the factory special tools and equipment.  If you're not a dealer, you usually do not have these things.  The Seloc manuals provide alternatives or workarounds to allow you to do the work normal tools and equipment.
I have the Seloc manual for my Mercury Black Max (Seloc Mercury Outboard Volume III, 1965-1991 6 Cylinder) and find the "Special Words" and "Very Important Words" and troubleshooting sections to be especially helpful.
Check out eBay for good deals on Manuals:
http://search.ebay.com/search/search.dl ... category0=
Good luck; see ya on the water!
April 27, 2008, 12:13:55 PM
Hardwater
« Reply #3 on: April 27, 2008, 12:13:55 PM »
Looking at manuals from our earlier boats, there are 2 Clymers for I/Os and 2 Selocs for outboards – don’t know why it worked out that way but it didn’t give me a chance to compare apples to apples.
There’s a lot of routine maintenance to do on this one (oil lines, fuel lines, fuel pump and filter, thermostat, etc.) just so there’s a known starting point.  Really don’t need a factory manual for that stuff I suppose – so another Seloc in the library.  If it comes down to it, the factory manual is always an option.
Thanks guys.
\'86 222 CCP
