Author Topic: Anchor weight & design for 170 Osprey  (Read 2136 times)
April 02, 2008, 04:14:30 AM
Read 2136 times
Bahi
« on: April 02, 2008, 04:14:30 AM »
I lost my anchor, during my last fishing trip. My 33 lbs fluke was doing great, especially in rough sea, but too heavy to carry & too large to store.
Anyway, I would like to buy a new anchor for my 17', before weekend. When I checked Doha marine shops, the salesmen suggested #8 fluke for 17'-24' boats, but I was confused between #13 (14 lbs) & #8 (9 lbs). I also found a 15.5 lbs CQR, but I never tried this model before.  <!-- s:? -->:?<!-- s:? -->
What do you suggest, weight & design wise?
Capt. Bahi is an Egyptian Sailor (Laser Class)
Sold to POUNDBURY:
\'84 Osprey 170 / \'97 Yamaha 115hp
April 02, 2008, 05:00:29 AM
  • Information Online
« Reply #1 on: April 02, 2008, 05:00:29 AM »
I would say a Danforth type in the 9LB range would be fine.  I'd add about 6-10ft of chain at the anchor and that should do you.
April 02, 2008, 08:49:59 PM
Anchor Size for 170
« Reply #2 on: April 02, 2008, 08:49:59 PM »
BTW Bahi,  I have a Danforth twice as big as you need I'm not using right now that I could sell you. Want me to throw it in my check-in bag?  <!-- s:lol: -->:lol:<!-- s:lol: -->
April 03, 2008, 09:47:40 AM
Anchor
« Reply #3 on: April 03, 2008, 09:47:40 AM »
My suggestion would be a Danforth type anchor of 8-9 lbs. with 4-6 feet of heavy chain and 3/8" nylon rode.  Something like this:
Hope this helps - see ya on the water!
April 03, 2008, 10:04:22 AM
slim
Anchor size for 170
« Reply #4 on: April 03, 2008, 10:04:22 AM »
this is what I use for my 19 6 an it's great. Even in rough seas it holds firm.
Slim
April 03, 2008, 11:26:59 AM
Bahi
« Reply #5 on: April 03, 2008, 11:26:59 AM »
Thanks guys! Based on your suggestions, I just got these:
The full set cost was $59.00; the anchor set for $9.00 & the plastic bag for $50.00  :wink:
THANKS EVERYBODY FOR USUAL GREAT HELP!
Sold to POUNDBURY:
April 03, 2008, 12:57:24 PM
Mad Dog
« Reply #6 on: April 03, 2008, 12:57:24 PM »
Quote from: "Bahi"
Bahi, when ever I use those a quick link between the chain and anchor I use a piece of stainless wire to tie the bolt in place.  I don't know exactly how but that link will come loose at the worst time.  The tie wire is just a little extra insurance.  :wink:
April 03, 2008, 01:47:03 PM
« Reply #7 on: April 03, 2008, 01:47:03 PM »
Expensive bag  :!:   :wink:
I agree with MD that you need to lock that clevis pin in with something- wire or a couple of small zip ties even.
April 04, 2008, 08:46:05 PM
Irish Rover
« Reply #8 on: April 04, 2008, 08:46:05 PM »
I have a similar setup, 9lb fluke with 10feet galvanized chain.  Works real good.  I use double the chain length in case I have to put out more scope due to swell, I find the anchor resets much quicker in rough water.  And like the other guys said make sure you put some wire through that shacle.  I use the stainless leader they sell for fishing, its easier to wrap a few times.  Make sure to have some sort of wrap for around the lead if you get stuck in some bad weather.  I use a peice of foam pipe insulator that I duck tape in place in case I have to wait out a storm.  Don't want that lead to chaf from the rubrail.
My back up is from my old sailboat a thirty pound fortress I keep in the dockbox with 15feet of half inch galzanized,  only take out for long trips up the hudson or through the D&R to virginia.
