Author Topic: CCP tackle locker install  (Read 2140 times)
March 30, 2008, 04:53:54 PM
Read 2140 times
« on: March 30, 2008, 04:53:54 PM »
I've been thinking about using some of the space between the hull and the liner on my CCP.  I fish shallow water mostly from the front, so some quick measurements showed I could install those neat tackle boxes there.   :wink:   Here's how the final product looks - and it's easy to do:
First some measurements - A 13" x 15" IPS 3-drawer unit will fit if you mount it 1" under the top lip of the liner and 8.5" in front of the stowage edge:
Tape the template to the hull (make sure it's straight!) and cut on the line.  I like to have nice rounded corners, so I cut 2" circles in the corners with a hole saw, then use the trusty sawzall to cut the straight sides:
After hole is cut out, check for fit and, if it fits, caulk the edges:
Install the screws, clean the excess caulk from the edges, and you're done:
Pretty cool!  I put one on each side - 6 tackle drawers at close reach!   :lol:
See ya on the water!
March 30, 2008, 07:38:12 PM
« Reply #1 on: March 30, 2008, 07:38:12 PM »
Nice Job GF  :thumright:
This might work on a lot of the "liner boats" - even my 170 :!:
What is the gauge in the pics for? Trolling motor voltage?
March 30, 2008, 08:44:20 PM
Update
« Reply #2 on: March 30, 2008, 08:44:20 PM »
Yes, the gauge gives volts for the main battery, which carries more load than the second battery, so it makes sense to monitor the main.  :wink:   The trolling motor is 24 volt, so it runs off both, but I also have a reserve battery for emergency starting just in case...   :oops:
March 31, 2008, 07:52:26 AM
« Reply #3 on: March 31, 2008, 07:52:26 AM »
Very cool.  I have also thought about adding more rod holder cutouts but have not investigated the clearances.  Why make the effort with gasoline prices...   :roll:
March 31, 2008, 07:56:33 AM
« Reply #4 on: March 31, 2008, 07:56:33 AM »
Now, are there any gasketed boxes that will fit?  I have switched all my boxes to the Plano with the rubber "o-ring" gaskets.  They do help keep your hooks from rusting.  (nothing prevents it completely)
http://www.planomolding.com/content/ind ... ctionid=67
March 31, 2008, 08:00:16 AM
« Reply #5 on: March 31, 2008, 08:00:16 AM »
Gonefission - can you post up a picture or two showing your trolling motor mount?  Looking to understand the best way to set it up on mine...
Thanks...
March 31, 2008, 08:42:17 AM
Trolling motor mount
« Reply #6 on: March 31, 2008, 08:42:17 AM »
I used the big MotorGuide removable mount with my MinnKota motor, so I can take it off if needed:
The CCP requires a trolling motor with a 60" shaft, so MinnKota is the way to go with the composite shaft.  Had to redrill the holes, cuz the bolt pattern is different for MinnKota and MotorGuide.  I also moved one of the bow cleats to make room for the trolling motor mount.
Here it is deployed and stowed:
March 31, 2008, 09:29:12 AM
« Reply #7 on: March 31, 2008, 09:29:12 AM »
Very nice - thanks.
How does that motor handle you 222?  Work well?
March 31, 2008, 10:28:50 AM
Trolling Motor
« Reply #8 on: March 31, 2008, 10:28:50 AM »
Mine is a MinnKota Riptide 70 with 70 lb thrust and Autopilot with wireless remote.  The autopilot feature with the wireless remote is great!  I can control the boat from the front, back, or even from a nearby dock if needed.  Also, the autopilot has a built-in compass, so it keeps a heading even if the wind or current changes.  The Riptide model is specially designed for salt water use; I would NOT buy a fresh water model - even occassional salt exposure could be troublesome...    :x
This motor has worked well for me, especially fishing back bays and grassy areas.  I've run it up on oyster bars a few times and the composite shaft really makes a difference.  Note this is a 24 volt motor, so you need 2 batteries and big wire - up to 50 amps - so #6 is about right.  I would not recommend a 12 volt motor for a 22 foot boat like mine - it's just too big and heavy for a 12 volt with 55 lbs...  :(    a 55 running on 12 volts might be OK on a 170.   :wink:
The newest model is the Riptide ST 80, with thrust now up to 80 lbs:  http://www.minnkotamotors.com/products/ ... _riptidest
Also, the propeller makes a difference, and I have replaced mine with a Kipawa prop - it really works!  You can check out Kipawa props at:
http://www.kipawapropellers.com/   :)
Hope this helps - see ya on the water!
April 01, 2008, 07:56:40 AM
« Reply #9 on: April 01, 2008, 07:56:40 AM »
Thanks for the trolling motor info.  That too is on my "someday" list  :wink:
April 01, 2008, 12:36:49 PM
jdupree
« Reply #10 on: April 01, 2008, 12:36:49 PM »
Great looking job GF :wink:   That is a great idea to use some of the "dead" space in the CCP'S :)
John L. Dupree, III
AQABLA84E999
Member #257
April 03, 2008, 05:17:52 PM
Tackle lockers
« Reply #11 on: April 03, 2008, 05:17:52 PM »
Took her out yesterday - nice to have the tackle nearby!   :D
And on the way back in - a little more "artistic"   :roll:
