Author Topic: Alloy Metal Works contact  (Read 1983 times)
March 27, 2008, 10:01:55 AM
Read 1983 times
« on: March 27, 2008, 10:01:55 AM »
According to Coast Guard Title 33 CFR and ABYC H-24 specs all fuel systems should be checked annually
http://alloymetalworks.com/
December 29, 2008, 11:57:16 AM
Fishhyren11
Re: Alloy Metal Works contact
« Reply #1 on: December 29, 2008, 11:57:16 AM »
Phone number no longer in service.
December 29, 2008, 05:56:30 PM
« Reply #2 on: December 29, 2008, 05:56:30 PM »
Try the other number:
631-694-8163
Good luck!   :cheers:
May 18, 2009, 11:47:00 AM
Fishhyren11
« Reply #3 on: May 18, 2009, 11:47:00 AM »
Phil,
I emailed you on 4/1/2009 and 5/4/2009 and did not hear back from you on either email.
Today is 5/18/2009
The email from 5/4/2009 was stating that when I placed the tank in the boat and filled it half way with fuel the gauge only showed about 1/8 a tank.
After fully filling it, it finally bounced up to the full mark.
My first trip out with the tank everything seemed to be working okay until about half way through the day the tank dropped down to show empty.
I re-filled the tank and the needle didn't move.
I thought it might have been a grounding issue, but I was able to rule that out.  When removing the ground the needle dropped completely, when I re-attached the ground, the needle jumped back to Empty.
It appears the float broke the first time of use (and stuck before that). Do you have any further suggestions or is it just a faulty float?
Thank you,
    -Scott
May 29, 2009, 02:44:52 PM
Fishhyren11
« Reply #4 on: May 29, 2009, 02:44:52 PM »
UPDATE:
Phil is sending me a new fuel sender (mine was faulty).
Thanks Phil!!
   -Scott
May 29, 2009, 08:05:49 PM
« Reply #5 on: May 29, 2009, 08:05:49 PM »
Thank you for spending the few minutes to post an update to this transaction - many a vendor have been left in a trashed reputation because the buyer never thought beyond them being happy with the resolution. I'm sure all vendors who lurk here appreciate your post.
