Known around here as Atomic Buffalo Turds
4 oz. cream cheese (from 8-oz. pkg.), softened
1 teaspoon grated lime peel
1 tablespoon chopped fresh cilantro
1 tablespoon lime juice
8 fresh whole jalapeño chiles
1 (8-oz.) can Pillsbury Refrigerated Crescent Dinner Rolls
1/4 cup butter or margarine, melted
4 oz. fresh Parmesan cheese, grated (1 cup)
1 . Heat oven to 375°F. Spray cookie sheet with cooking spray. In small bowl, mix cream cheese, lime peel, cilantro and lime juice until well blended; set aside. Carefully remove stems from chiles; cut each in half lengthwise. Remove and discard seeds. I recommend surgical gloves for preparing the jalapeños.
2 . Unroll dough on cutting board; separate into 8 triangles. From center of longest side to opposite point, cut each triangle in half, making 16 triangles.
3 . For each appetizer, spoon 1 teaspoon cream cheese mixture into chile half; place chile, cream cheese side down, on dough triangle with point of chile near top point of triangle. Wrap sides of triangle up over chile; pinch to seal. Bring point of triangle down over end of chile to cover; pinch to seal.
4 . In separate shallow dishes, place melted butter and Parmesan cheese. Dip each dough-wrapped chile into butter; roll in cheese to coat. Place on sprayed cookie sheet.
5 . Bake at 375°F. for 10 to 15 minutes or until golden brown. Immediately remove from cookie sheet. Serve warm.
I discovered last year to NOT buy the wrinkled jalapeños from the roadside Mexican vegetable stands. They are hotter than this old man can stand.
This is not an original by me, just something someone passed along.
