new fuel tank
Topic: new fuel tank (Read 1253 times)
March 03, 2008, 07:49:39 PM
Read 1253 times
Carvguy
new fuel tank
March 03, 2008, 07:49:39 PM »
Well I finally pulled my fuel tank on my 1987 222 express fisherman!
And just as everyone has said right under the strap there is 2 small areas that are corroding.
Was thinking of just having them welded but, I don't think that would give me the same peace of mind that a new tank would. Ive been looking around and the closest one I can find is a 55 gal from west marine.[I'm from Northern California]I'm not going to be going out the gate much so most of my time will be in the Sacramento delta area so I don't need 85 gal 55 or so would be fine.Any Ideas on model and or location would be appreciated.
Thanks as allways Carvguy
March 04, 2008, 07:30:42 PM
Saint P
March 04, 2008, 07:30:42 PM »
Moeller Marine 55 Gallon Belly Fuel Tank Below Deck, take a look at this one. Just do a search for it on google.
March 04, 2008, 09:31:17 PM
March 04, 2008, 09:31:17 PM »
I am not thrilled with a plastic tank below deck - seen a few fail in no time on classicmako...
Have a tank built. I went to RDS in Perry, FL - but there are many fabricators that will be happy to build you a tank.
March 26, 2008, 02:01:35 PM
saabmarine
March 26, 2008, 02:01:35 PM »
even including shipping Sunshine Marine in Florida was the cheapest I found and I compared about 10 local and non local shops to make a 150 gallon tank and 50 gallon tank for me. Also check out Ketfab Marine if you're local to new england.
1985 Mako 254
1998 Merc 250HP
Boston, MA
March 28, 2008, 12:45:37 AM
aqua70
fuel tank
March 28, 2008, 12:45:37 AM »
we have had a plastic tank 85 gallons in our Four Winns with no problem.
Try
www.boatingchannel.com
They have some real REASONABLE tanks for sale. We replaced our Aquasport 17' with an 18 gallon tempo.
March 28, 2008, 05:24:13 PM
Tank
March 28, 2008, 05:24:13 PM »
The 222 XF uses the same tank as the CCP - 85 gallons. Phil at Alloy Metal works custom made mine in a week for $650. Pics and info at:
http://classicaquasport.com/smf/index.php?topic=2597.0
Here's the contact info (ask for Phil):
ALLOY METAL WORKS CUSTOM MARINE FUEL TANKS
631-694-8163 TOLL FREE 1-888-549-9353
http://www.alloymetalworks.com/4752.html
Good luck!
April 05, 2008, 10:07:37 AM
Saint P
April 05, 2008, 10:07:37 AM »
Why would anyone consider going back to aluminum if they fail over time, ie:
corrosion issues. That's why I think it would be better to go with a composite. I'm in the process of changing mine over now and I'm just trying to wrap my brain around the whole aluminum thing.
April 08, 2008, 08:05:42 PM
Saint P
April 08, 2008, 08:05:42 PM »
Found out recently that Tempo is out of business. If anyone is considering composite it looks like it will have to be Moeller.
new fuel tank
