Author Topic: 1990 Osprey 20' fuel tank  (Read 862 times)
February 26, 2008, 12:02:24 PM
Read 862 times
Saint P
« on: February 26, 2008, 12:02:24 PM »
I repowered last season with a 115 mercury 4 stroke.  After about 15 hours I had serious fuel problems.  The boat still has the original 55 gal aluminum gas tank, the problem with the motor seemed to be clogged injectors.  They had a white powdery substance plugged up in them.
The shop recommended replacing the fuel tank.  I thought they only had problems with fiberglass ones.
Has anyone replaced their 55 gal belly tank before?  If so, what can I expect?
February 26, 2008, 01:02:26 PM
« Reply #1 on: February 26, 2008, 01:02:26 PM »
How old is the tank?
Aluminum tanks can have issues too...
February 26, 2008, 03:07:24 PM
Saint P
« Reply #2 on: February 26, 2008, 03:07:24 PM »
It's a 1990
February 26, 2008, 06:57:38 PM
« Reply #3 on: February 26, 2008, 06:57:38 PM »
I replaced the aluminum tank on my 84 in 97. It suffered from the same syndrome they all eventually get; strap corrosion. That's 13 years old.
You may be due.
February 27, 2008, 08:29:29 AM
jdupree
« Reply #4 on: February 27, 2008, 08:29:29 AM »
When I bought my 1988 170 I did not know at the time, but when I filled her up I found out my tank was bad.  As stated, 99.9% of the corrosion comes from under the straps.  At the minimum, I would pull the tank and inspect it.
John L. Dupree, III
AQABLA84E999
Member #257
