I am getting ready for the coming boating season on the Illinois River. One project is to replace a poorly functioning engine control unit on my 1982 Express Fisherman that is powered by a 1986 225 Yamaha outboard motor.
The current control unit is an old single lever, dual function Morse with power trim and tilt. It is very stiff, often refuses to move into neutral position, generally gets out of adjustment easily causing a lot of grinding in and out of gear, and tries to drop back into gear when you want to add rpms in neutral.
What should I replace it with? Should I go with a single lever dual function unit or with a dual lever single function unit? What specific brands and models (that include power trim and tilt) would any of you recommend? What dealers can I get them from?
Thanks very much
