Author Topic: Make your own LED lights  (Read 2530 times)
December 21, 2007, 05:15:10 PM
Read 2530 times
« on: December 21, 2007, 05:15:10 PM »
LEDs lights are the way to go - but seem sooo expensive to buy  :cry:
Here's how to make your own and save a bunch:   :idea:
1.  Buy some 5mm flat-top white LED bulbs - you want to get the flat-top if you can, as they have a 90 degree beam versus the 20 degree beam of the round-top ones.  You can get them on eBay for a few $$ for 50 or so:  http://stores.ebay.com/Light-of-Victory ... idZ2QQtZkm
2.  Note LEDs are polarized and have a + and - the long lead is +  LEDs run on 3-4 volts, so we are going to put 3 in series for a 12 volt connection - this eliminates the need for resisitors, making the job even easier.
3.  Let's get to work - solder 3 or 4 LED bulbs + to -   You want to keep them close together, and leave the leads intact on both ends.  If your electrical system puts out more than 14 volts, use 4, not 3.  Here's how they look soldered together:
4.  Make 2 sets of 3 or 4 bulbs each, then solder them together - keep polarity right, make sure + is on one end and - is on the other.  Also note the polarity for the bulb socket - the wire will be red for + and black for - :
5.  Check the height of the leads compared to the original bulb.  You wan the LEDs to be the same as the filament in the bulb.  Bend the leads down, cut them to the proper height, and solder them to the bulb contacts in the bottom of the bulb holder.  You can solder them because LEDs last 20,000 hours -  :shock: - you will not be needing to change them out!
6.  Make sure the LEDs are evenly spaced about 60 degrees from each other and make a nice, even pattern.  Fill the inside of the bulb holder with 5200 or other good caulk to stabilize the leads and hold it all solid.
7.  Make sure the LEDs are all even and straight, screw the lens back on, and put power to it!  If you did it right, it will look like this:   :D
8.  Why go LED?  One reason is power consumption.  A standard anchor light bulb is 9 watts, or .8 amp.  Check out the power consumption on the LEDs - the meter is reading amps - less than 1/10 of that - not even a watt!  If you have 3 lights like my 22-2CCP, that means power for the lights goes from 27 watts (about 2.5 amps) down to less than 3 watts (a quarter of an amp) that really makes a difference when you are out fishing at night or running a bunch of electronics on an old motor that only makes about 10 amps charging power.
 :wink:
Good luck!
December 21, 2007, 11:31:09 PM
« Reply #1 on: December 21, 2007, 11:31:09 PM »
Excellent post Capt. John.  I have been planning on doing that myself.
What I really want is to re-do the 55 watt halogen spreader lights.  Those suckers will kill a battery in no time.  I just want enough light to tie on hooks and un-hook fish.
December 22, 2007, 09:18:03 AM
LED Spreader Lights
« Reply #2 on: December 22, 2007, 09:18:03 AM »
There are some nice LEDs to replace those spreader lights.  Check out these 3 watt units:
http://cgi.ebay.com/3x1W-3W-MR16-WHITE- ... dZViewItem
These would be an excellent replacement and drop power consumption by 90%.   :wink:
December 22, 2007, 09:49:21 AM
« Reply #3 on: December 22, 2007, 09:49:21 AM »
Very interesting.  I'll have to look into that.  It looks like a much better option that trying to build my own.
Thanks for the link.
December 22, 2007, 10:25:59 AM
LEDs
« Reply #4 on: December 22, 2007, 10:25:59 AM »
That dealer has some pretty interesting light options:
http://stores.ebay.com/LEDBulb-Bizz
These folks are out of Hong Kong - great prices and I've gotten delivery in about a week:
http://stores.ebay.com/TopBright-Led-Store
http://stores.ebay.com/Shop4leds
Good luck!
August 18, 2008, 07:49:19 PM
compcrasher86
« Reply #5 on: August 18, 2008, 07:49:19 PM »
So I went out to radioshack cause I couldnt wait and I bought 6 LEDs for a buck a piece. I soldered carefully, wired and tested. everything looked great, and bright :). Then I decided, instead of going to the garage to grab some 5200, hot melt glue would work fine. Worst decision EVER. now half of my LEDs are flickering, 2 are blue? and one is just not working. DARN MY LAZINESS! well at least LEDs are cheap. Oh and also, instead of soldering into the socket, I put the LEDs in a bottlecap and soldered 4 foot lead wires to just replace the socket.
Update:
I got my Topbright LEDs today and since the boat is right in my yard, I had them installed within 30 minutes. The sunset tonight was awesome so I had to use it as the backdrop. Not as bright as yours but still looks good and it will probably be brighter at night
Stock 1973 222 Open Fisherman
"Floor it"
