Author Topic: Nebie Non Aquasport Flat Back Question  (Read 1021 times)
December 20, 2007, 06:22:18 PM
Read 1021 times
Jettyman
« on: December 20, 2007, 06:22:18 PM »
Hello all - I've been reading this forum a lot and now that I've found a boat I figured it was time to join - The problem though is that my boat is not an Aquasport, but a 17 Ft Flatback Manatee - The boat is very solid (except floor)
My 1st questions are: Is anybody familiar with this boat? Has anybody every rode in the 17 ft flatback? and what size power shall i put on her.
Thanks in advance (to be honest, I was looking for an AS 175, but this boat fell in to my lap at the right price :lol:
December 21, 2007, 09:01:55 AM
« Reply #1 on: December 21, 2007, 09:01:55 AM »
Don't know anything about the hull, but would appreciate pics.
I would guess (ONLY a guess) that it might do well with something in the 100 hp range.
December 21, 2007, 05:24:20 PM
Manatee
« Reply #2 on: December 21, 2007, 05:24:20 PM »
You may have a Manatee VC17 - made in the 70s and 80s, I think.  Max power was 115 on those.
If it's from the 60s and a little less than 17 feet, it could be a MK2 - again with a 115 HP max.  If it's closer to 18 feet, it might be a MK3 - those were rated up to 140 HP.
A 115 would seem to be a good motor for any of these models.
Hope this helps - good luck!!
December 21, 2007, 07:13:31 PM
Jettyman
« Reply #3 on: December 21, 2007, 07:13:31 PM »
thanks for the responses
I'll try to take some pics in the morning - The boat title says it's a 1976 18'.6", but I measured it when I got it home and it's 17 ft on the nose -
any info on how this hull performed? Also, I'm thinking of powering her with a 90 just to save a little at the pump.
I think the flat bottom should make for some interesting handling.
December 21, 2007, 08:21:12 PM
Engine
« Reply #4 on: December 21, 2007, 08:21:12 PM »
It depends on what engine you choose.  Mecury 90 and 115 four-stroke engines use the same block and have the same weight, so you won't see much difference.  Evinrudes e-tecs are different - the 90 is a 3 cylinder engine and the 115 is a 4 cylinder engine - not sure about fuel economy on one versus the other, but they ARE different engines.
To clarify some of the above, I remember a recent test between a 250 single and twin 115s from the same manufacturer.  You would think that the twins would take more gas and be less efficient, but actually the twin 115s out-performed the 250 in every area except cost and weight, and cost was closer than one would think...  So a 4 cylinder is not necessarily more of a gas hog than a 3 cylinder.  If you want a Merc, I would go up to 115.  If you are thinking 'Rude, look a weight and other factors to decide between a 3-cylinder 90 and a 4-cylinder 115.  Remember that the 3 cylinder 90 has a history that I think goes back to the old 70 horse from some 30 years ago - the engine has been around a while, with a proven history.  The e-tec 115 is a newer 60 degree V-4 that replaces the old 90 degree V-4 that OMC used for years.  The new engine is basically a V-6 e-tec with 2 cylinders cut off.  It's about the same weight as the Mercs (just under 400 lbs.), but the 90 is some 70 lbs lighter at 320 lbs.
So there's a bit to consider!  Good luck!
December 21, 2007, 09:35:13 PM
Jettyman
« Reply #5 on: December 21, 2007, 09:35:13 PM »
what do you think of the older evinrude/johnson 4 cyl 88 SPL or 90 HP?
December 21, 2007, 10:46:29 PM
88 and 90
« Reply #6 on: December 21, 2007, 10:46:29 PM »
The 4-cylinder 88 and 90 models have a great reputation, with the exception of some of the VRO models that had lubrication problems.  You see some old ones that are really beat up and obviously have had a hard life, yet start every time and keep running.  A 90 degree V-4 is a nicely balanced engine - like a 60 degree V-6.  When OMC originally made their V-6 engine, they just added 2 cylinders onto the V-4, which made for an unbalanced engine.  A 90 degree V-6 will generate good torque, but will have problems with high RPMs due to the inherent balance problem.  That's why the Mercury V-6s could wind so high - nicely balanced 60 degree block that would run all day up to 7000 RPM.
It looks like OMC/Bombardier have reversed themselves in the latest 4-cylinder, going with a 60 degree V-4 that looks like the V-6 minus 2 cylinders.  Time will tell if it builds the reputation of the old V-4s...
January 04, 2008, 12:15:03 PM
intheblood
« Reply #7 on: January 04, 2008, 12:15:03 PM »
I have a 2001 Yami 90 2-stroke on my'88 170. I got this motor new old stock for $2500. This motor replaces the 70 Yami that came on the boat new. These two motors are basically the same and fuel economy has actually improved with the 90.
\'87 170
\'87 200
\'93 210
\'93 230
all Yami powered
January 09, 2008, 09:21:24 AM
Jettyman
« Reply #8 on: January 09, 2008, 09:21:24 AM »
There is no internal fuel tank on my boat - Would an 18 Gallon tank be enough for a day on the water with an older 2 stroke 90? What type of range could I expect on 18 gallons?
