Props
Prop blades - is mo' bedda?
Topic: Prop blades - is mo' bedda? (Read 2942 times)
November 13, 2007, 09:26:14 AM
Read 2942 times
Mechanical Master
November 13, 2007, 09:26:14 AM »
Got a new birthday prop and tried it out over the weekend. Went with a 5 blade Mercury/Quicksilver High Five in 19 pitch. Compared to my old 3 blade Mercury/Quicksilver Power 2 stainless in 19 pitch, here are the results:
Hole shot = very good with 5 blade, smooth too.
Top speed = 40 with 3 blade at 5300RPM, 44 with 5 blade at 5500RPM
Efficiency = 3 blade was 10 gal/hr at 30 MPH, 5 blade is 8.9 gal/hr at 30 MPH.
So it looks like the new 5 blade High Five is a winner on my boat! The 5 blade prop has a diameter almost 1" smaller than the 3 blade it replaced, so that probably allows more trim before cavitation. Note that all the above specs are with the motor trimmed for optimum efficiency. I will run a full RPM/Speed/Mileage set later and post the full chart. But for now, I'm a happy camper!
I guess mo' is bedda!
Here's a picture (prop porn):
See ya on the water!
November 13, 2007, 10:20:03 AM
November 13, 2007, 10:20:03 AM »
Verrrrry interesting. I have no experience with 5 blade setups... interested to see if everyone has seen similar results. Good stuff.
November 13, 2007, 01:26:18 PM
November 13, 2007, 01:26:18 PM »
wicked looking!
November 13, 2007, 02:45:36 PM
November 13, 2007, 02:45:36 PM »
Not to be rude, but price please?
November 13, 2007, 05:29:55 PM
71flatback
November 13, 2007, 05:29:55 PM »
awesome!!!
1971 aquasport 22-2 flatback, Work in progress
November 13, 2007, 06:37:35 PM
November 13, 2007, 06:37:35 PM »
Looks like it'll stir some water 8)
BTW - HAPPY BIRTHDAY :dj: :shaking2: :bounce:
November 13, 2007, 07:29:15 PM
Mechanical Master
High 5 price
November 13, 2007, 07:29:15 PM »
List price on the High Five is about $550
They are going on eBay for $250 - $350; that's where I got mine.
At $3.00 per gallon for gas, it will pay for itself in about 80 hours of use. Lots cheaper than a new engine!
Here's what Trailer Boat had to say:
http://www.trailerboats.com/output.cfm?id=1069057
More info on Mercury's web site:
http://sites.mercurymarine.com/portal/p ... ema=PORTAL
November 13, 2007, 09:00:22 PM
jdupree
November 13, 2007, 09:00:22 PM »
John,
I am looking to re-prop mine. Are you interested in selling your old prop? Is it stainless steel?
John L. Dupree, III
AQABLA84E999
Member #257
November 13, 2007, 09:12:46 PM
Global Moderator
November 13, 2007, 09:12:46 PM »
I'm running a four blade ss "Renegade" on my 200 Rude. It performs much better (and allows proper rpm range operation) than the three blade alum or stainless wheels. Anyone else running one on their Johnson (that doesn't sound right)/Evinrude.
November 14, 2007, 07:48:56 AM
Reply #9 on:
November 14, 2007, 07:48:56 AM »
I don't put
anything
on my Johnson
I have a 4 blade Predator with open vent holes on my 225 OceanRunner. I do not remember the diameter or pitch. It gives me a decent hole shot and hits 5900/40 mph at WOT. Fuel consumption we are not going to talk about :cry:
November 14, 2007, 08:59:26 AM
Global Moderator
Reply #10 on:
November 14, 2007, 08:59:26 AM »
Quote from: John Jones
I don't put
anything
on my Johnson
I'm rather fond of latex myself..oh sorry, wrong Forum
December 17, 2007, 07:57:47 AM
DP
Reply #11 on:
December 17, 2007, 07:57:47 AM »
do they make 5 blades for Yamaha's?
ON~ON
December 17, 2007, 08:28:03 AM
DP
Reply #12 on:
December 17, 2007, 08:28:03 AM »
I did some research and they say that Merc & Yami props wll fit on either outboard. Can anyone here back that up?
I also found a prop on Craigslist in Texas.
http://fortmyers.craigslist.org/boa/503063788.html
ON~ON
December 17, 2007, 08:35:54 AM
Reply #13 on:
December 17, 2007, 08:35:54 AM »
I know that some will but I am not sure about all.
Ken can answer any prop question you have.
http://propgods.com/content/index.aspx
December 17, 2007, 02:59:33 PM
Mechanical Master
Props
Reply #14 on:
December 17, 2007, 02:59:33 PM »
Yamaha V-6 outboards use the same prop shaft setup as Mercury V-6 outboards and Mercury Alpha outdrives. The propellers are interchangeable, but I think the thrust washers are different. Of course, if you're just changing the prop, you would use the old thrust washer anyway...
Hope this helps!!
Props
