Author Topic: Removing lower motor mounts - 1992 200 Mercury  (Read 717 times)
October 28, 2007, 08:53:31 PM
Read 717 times
jdupree
« on: October 28, 2007, 08:53:31 PM »
I am trying to replace the lower motor mounts on this engine.  I have removed the motor mount nuts on the front of the yoke.  The head of the motor mount bolt is on the leg side.  What I am trying to figure out is how do you remove these bolts?  I don't have enough clearance to pull the bolt out because it is hitting the leg.  I have tried pushing the motor up while trying to remove these bolts from the yoke.  I have a Seloc manaul but this is not covered in there.  Any help would be greatly appreciated.
John L. Dupree, III
AQABLA84E999
Member #257
October 29, 2007, 05:23:12 AM
  • Information Online
« Reply #1 on: October 29, 2007, 05:23:12 AM »
Hi John, maybe you should ask the same question on this forum.
October 29, 2007, 09:20:39 AM
jdupree
« Reply #2 on: October 29, 2007, 09:20:39 AM »
Rick,
I have already posted there, but wanted to see if anyone on this site has ever had off the motor mounts.  I just can't figure out how to remove the bolts from the motor mount without having to cut them.
John L. Dupree, III
AQABLA84E999
Member #257
