Author Topic: Scupper Drains : How far above the waterline ?  (Read 1323 times)
October 09, 2007, 03:37:07 PM
Read 1323 times
RebelYell
« on: October 09, 2007, 03:37:07 PM »
Howdy Aquasport Boaters -
I have been reading ( and occasionally posting ) in this forum for months.
In March, I purchased a 1990 Osprey 200 with a Mariner 150 of the same year.
I have been going through the boat and notice that occasionally, when I stand near the transom, a little water comes in through the scuppers. Never much, but maybe a quart or so. I weigh 220 lbs.....
My question is:
How far should the scuppers be above the waterline for my boat with my motor and say, a half tank ( 22 gallons ) of fuel...without me in it.
I am trying to get a general idea. Also, a guy at the marina who forklifted my boat a few times said it felt somewhat heavy...of course this is an older boat with a solid (non cored) hull so it should be heavier than alot of the boats he handles. I have never inspected the stringers and am praying they are not wet.
Thanks for the input and hopefully I can get a general idea of what a reasonanble height above waterline for my scuppers should be.
I really enjoy this forum !
Tight lines..................RebelYell, Winter Haven, FL
October 09, 2007, 04:13:21 PM
jdupree
« Reply #1 on: October 09, 2007, 04:13:21 PM »
That is going to be the norm for the Osprey's.  With no one in the boat, they should sit just above the water.  When a person stands at the back, the scuppers usually become submerged.  Do a search on the forum for scuppers and there are several threads on this.
John L. Dupree, III
AQABLA84E999
Member #257
October 09, 2007, 04:28:33 PM
RebelYell
« Reply #2 on: October 09, 2007, 04:28:33 PM »
Quote from: "jdupree"
Thanks man.
Reading all this stuff about wet stringers makes me nervous; as I am getting ready to paint my baby with Interlux in a couple of months.
Could one assume, then, if the scuppers are just above the waterline that the stringers are prolly OK ?....as in no more excess weight ?
Also, on the stringer topic, was this a problem in the later manufacture boats or is it a problem for all models young and old ?
You guys on here rock.  8)
October 09, 2007, 08:11:38 PM
« Reply #3 on: October 09, 2007, 08:11:38 PM »
My 230 is fine but the scuppers are under water on my 170 all the time.  :roll: Too heavy of a motor I guess.
October 09, 2007, 08:55:07 PM
« Reply #4 on: October 09, 2007, 08:55:07 PM »
My 22-2 burps a little water now and then if there are a couple of people in the back.
Heck, check out a $40K Pathfinder.  Lots of manuf. have not learned yet.
October 11, 2007, 01:47:15 AM
ddd222
« Reply #5 on: October 11, 2007, 01:47:15 AM »
sounds real normal for the scuppers to dip below the waterline when an adult male is far aft on that boat. If that amount of water bothers u, or if u have 3-4 passengers often, u can upgrade ur scupper design to the rubber flap design, or even more effective "ping pong"ball design. Both intended to get water out but not allow any in.
      BUT, i think u said u were going to the trouble of painting here,and if u ever repower, modern 4 stroke and d.i. motors weigh significantly more. In my friends case bringing his scuppers under water at rest at the dock. . After investing a bomb in a new 4 stroke, he had to glass up the old scuppers and create new ones somewhere around and inch higher. Just a thought but worth mentioning
