Now I'm starting to plan for the deck sole replacement. I'm going back and forth between exterior plywood and marine plywood -- my checkbook says save a few bucks and go with exterior, but I keep thinking marine plywood. Any thoughts?? How about thickness?? Seems like the old deck/sole had 1/2" (might be 3/8") if I remember correctly, any recommendations?? I've been looking through a bunch of different rebuilds and have gotten alot of good information, but haven't yet found (maybe I haven't looked hard enough) a good way to secure the fuel tank in the coffin. The old tank had the straps with screws that went thru the coffin and into the stringers which over time wore bigger holes into each. I want to avoid that problem all together. Should I still go with straps and find a better way to anchor or is there another method?? And finally, I want to do all I can to prevent water from getting into the deck/sole -- anchoring the console -- previously it was anchored to 3/4" trim under the console and that trim was screwed to the deck. Is there a better way?? I know, bunch of questions but I don't want to get too far down the road on the rebuild and wish I did something else. Appreciate any feedback/input and I will get the pics up soon.
Need some advice -- I am thinking about eliminating the rigging trough on the starboard side of the deck/sole that runs from the side of the center console aft and replacing it with a rigging tube which would run under the deck/sole and come out on the starboard side just forward of the transom about 6-12 inches above the deck/sole. This would also eliminate the small trough at the transom where the old drains were located. Reasoning -- trying to eliminate a bunch of glass work required to rebuild the trough and also eliminate 2-3 inches of depth required for the cockpit drains (cockpit drains would be slightly higher than original which in "theory" would help out the draining problems). Any comments?? Recommendations??
