Author Topic: fill hose  (Read 1973 times)
October 02, 2007, 08:20:35 PM
Read 1973 times
drzdave
fill hose
« on: October 02, 2007, 08:20:35 PM »
does any body have an easy way of replacing  the fill and vent hose on my 76/170 as i was trying not to cut an access hole
76 / 170
October 05, 2007, 08:11:09 AM
aqua70
fuel line
« Reply #1 on: October 05, 2007, 08:11:09 AM »
Where is you fuel tank located?
October 06, 2007, 06:35:05 PM
drzdave
« Reply #2 on: October 06, 2007, 06:35:05 PM »
the tank is in the coffin
76 / 170
October 07, 2007, 12:54:00 AM
those guys
fuel hose replacement
« Reply #3 on: October 07, 2007, 12:54:00 AM »
If you have not yanked the old hose out yet, you can use a double nipple fitting to connect the new hose to the old hose with no obstruction or increase in diameter. You can heat the hose with hot water to make it slip over the nipple fitting. If you can't find the right nipple or barb fitting then use a threaded fitting.  Then you simply pull the new hose into place using the old hose as a fish tape.
Bob
1974 19-6 Creampuff
1968 222 Diver
October 07, 2007, 09:49:45 AM
drzdave
« Reply #4 on: October 07, 2007, 09:49:45 AM »
thanks but the hoses didnt even want to move back and forth so i pushed the hoses in and used the old hose as a guide and left the old hose in place it work pretty good
76 / 170
October 07, 2007, 10:45:51 AM
« Reply #5 on: October 07, 2007, 10:45:51 AM »
Quote from: "drzdave"
Coming in late on this but I'd bet the old hose wouldn't move because it had been foamed around. Is your fill located on the gunwale?
October 07, 2007, 11:04:55 AM
drzdave
« Reply #6 on: October 07, 2007, 11:04:55 AM »
yeah so i just left them in there disconnected
76 / 170
April 20, 2008, 06:56:30 PM
wwwcre8r
    • http://www.cre8r.com
Fuel Fill Hose - can't get old one out!
« Reply #7 on: April 20, 2008, 06:56:30 PM »
I have an '87 AS Osprey 170... I can't get the old fuel fill hose out, I can't even budge it more than an inch!
I have the console off... the old tank out of the coffin, the new tank built and ready to go in... but the old fill hose is corroded and nasty, can't keep it.
Maybe it is foamed in... maybe it is wedged against a stringer... not sure where to go from here, any help is appreciated!
1987 Aquasport 170 Osprey, \'87 Mercury Mariner 115 L6
April 20, 2008, 09:46:25 PM
« Reply #8 on: April 20, 2008, 09:46:25 PM »
Well this won't win any awards but when I replaced mine, I ran into the same problem. I ran a new hose from the tank to the back (steering) side of my center console and relocated the fill cap.
Problem with this is that you have to be in the boat to fill the tank.
Definitely not for everyone but works fine for me.  :wink:
April 20, 2008, 10:10:17 PM
wwwcre8r
« Reply #9 on: April 20, 2008, 10:10:17 PM »
Quote from: "Capt. Bob"
Thanks for the info... I was hoping to not have to relocate the fuel fill location... I might be able to run new hose though, if I could only get the old one out - why would anyone install the hose so that it couldn't be replaced?
April 21, 2008, 07:53:17 AM
Bushleaguer
« Reply #10 on: April 21, 2008, 07:53:17 AM »
It may be different on my 22-2 osprey, but on it, the fuel fill hose was secured by a zip tie that was screwed to the inside, vertical bulkhead of the casting deck.  It was accessible thru a 4" round inspection hatch in the starboard hatch in the casting deck.  That access hatch gave enough room for me to get in there, cut the zip tie and use one hand to work the hose thru.  After the new fill hose was in place, I was able to secure it in the same manner with a zip tie.  It was a pain, but turned out OK.
April 21, 2008, 09:31:36 AM
wwwcre8r
« Reply #11 on: April 21, 2008, 09:31:36 AM »
Thanks for the info... I have an access port in the starboard locker up front, it is about 10" away from where I would imagine the hose crosses the stringer... if I'm lucky I might be able to get my arm up in there far enough to remove any zip tie, etc.
If worse-comes-to-worse, I could cut a hole in the locker, close to the hose, then repair that afterwards (better than the deck).
April 21, 2008, 08:07:04 PM
jsakat1
« Reply #12 on: April 21, 2008, 08:07:04 PM »
Wow! I am changing tank and had planned to change the fuel hose...same problem that thing has foam weighing on it and it wouldn't budge.....
Can we class action sue Genmar? the company that makes aquasport. (joking here) Because that hose is stuck in there. won't budge.
1987 170 Striper
April 22, 2008, 09:56:22 PM
« Reply #13 on: April 22, 2008, 09:56:22 PM »
Likely nobody at the plant reckoned the boats would out-live the hoses.
July 06, 2008, 08:57:54 AM
wwwcre8r
« Reply #14 on: July 06, 2008, 08:57:54 AM »
I finally got the old fuel fill hose out!  :D
That was the biggest PITA job ever, I ended up cutting the opening larger in the coffin where the hoses enter, reaching my hands up in there to work the hose loose, used a lot of bubble soap as a lubricant, nearly broke my back doing this, thank God it's over now.
