Author Topic: gas tank  (Read 895 times)
October 01, 2007, 11:34:27 PM
Read 895 times
drzdave
gas tank
« on: October 01, 2007, 11:34:27 PM »
are you supposed to ground the fill inlet to the tank then to the battery ground  does it matter
76 / 170
October 02, 2007, 08:30:43 AM
Grounding
« Reply #1 on: October 02, 2007, 08:30:43 AM »
Drzdave,
My inlet has been relocated to the center console (was on top of the starboard gunwale). I have the inlet grounded to my main ground buss. The tank itself has a seperate ground back to the same buss. My thought was to eliminate a chance for sparking to occur when fueling. It could be grounded to the tank itself but you still need to ground the tank in order to be effective (unless I'm missing some electrical theory I never learned). I'm still here afer installing the new tank several years ago so either I did something right or grounding the inlet/tank doesn't do anything.
Good Luck
October 02, 2007, 08:42:04 AM
« Reply #2 on: October 02, 2007, 08:42:04 AM »
Yes: fuel fill to tank, tank to battery.
