Author Topic: hull restore question  (Read 1054 times)
September 25, 2007, 11:31:21 AM
Read 1054 times
wiler55
« on: September 25, 2007, 11:31:21 AM »
when you are putting in the stringers and the bulkheads what kind of fiberglass do you want to reinforce the hull not the stringers but underneath them. it seems like to me that you would want to use a coupple layers of some heavy woven stitch mat. i am also talking about what will go from the bottom of the hull up the sides. should i use the same stitch? heavier on the bottom than on the sides or what?
September 25, 2007, 12:40:45 PM
« Reply #1 on: September 25, 2007, 12:40:45 PM »
I used stitchmat.  For any inside corners, build up the corner with a fillet so the mat lays into the corner with a radius.  See Lilrichard's and Shine's project pictures.
September 25, 2007, 03:02:13 PM
wiler55
« Reply #2 on: September 25, 2007, 03:02:13 PM »
im talking about under the stringers and the bulkheads running from the bow to the stern and the chime to where the top cap tuches the side of the hull on the inside i wanted to lay new fresh fiberglass. was wandering if i should use a heavy stitch mat or if a coupple layers of 1707 is ok.
September 25, 2007, 03:31:16 PM
« Reply #3 on: September 25, 2007, 03:31:16 PM »
I used stitchmat there too.  Good stuff.
Make sure it is double bias:
http://www.mertons.com/Reinforcements/d ... titch.html
September 25, 2007, 03:44:12 PM
The Bear
    • http://www.BearPawsWeather.com
« Reply #4 on: September 25, 2007, 03:44:12 PM »
Wiler...If you wouldn't mind, and its not too much of a PITA, would you please post pics as youre coming along? I am going to be new to this too and putting pictures with some of your questions might help me along the way then it comes time for me too! Thanks!
September 25, 2007, 03:45:40 PM
« Reply #5 on: September 25, 2007, 03:45:40 PM »
I think you are talking different materials.  Jim's 24oz material is actually the same as 1707 (some say Tomato).  I think Wiler is talking about 2415.
