Author Topic: Boat Trailer  (Read 1908 times)
September 23, 2007, 11:37:52 AM
Read 1908 times
KeithG
Boat Trailer
« on: September 23, 2007, 11:37:52 AM »
Since the purchase of my '87 Osprey 200, I have been on the lookout for a used trailer in good condition.
I have had no luck.  So now I am looking for a new trailer, I am sure you guys have plenty of suggestions.
First, What size trailer do you suggest I need? Length, width, trailer type.
I do want tandem axle.  I am willing to drive to pick up.
My boat is sound, and getting better all the time as I make upgrades, but right now the trailer is preventing me from going where I want to go.
I live in Lafayette, LA, I can easily fish the TX, LA, and MS coast... if only I had a trailer.
September 23, 2007, 08:02:01 PM
« Reply #1 on: September 23, 2007, 08:02:01 PM »
These have the absolutely best reputation around here but I have no experience with them.  They are probably the most $$ also.
http://www.rollsaxle.com/boat_trailers.htm
I will try to discourage you from buying a ShoreLand’r trailer.
http://www.shorelandr.com/
I had a new '02 ShoreLand’r "ALUMINUM" trailer with a Key West 1900.  The trailer frame was solid and looked good.  Almost ALL of the bolts, accessories, and hardware were cadmium plated.  The crossmembers were galvanized.  Mixing three different metals and saltwater caused major corrosion everywhere two dissimilar metals touched.  I had to start replacing bolts before two years were up and the aluminum frame was pitted severely where the galvanized steel crossmembers were bolted to the aluminum frame with cadmium plated steel bolts.  The light wiring totally sucked.  Everything was connected with those little blue pinch-on splices that cut into the wires.  I started having bad connections after three launches and both light sockets were corroded beyond use at 6 months. /end Soapbox
September 23, 2007, 09:43:43 PM
KeithG
« Reply #2 on: September 23, 2007, 09:43:43 PM »
Thans JJ.
I have time to make my decision, so I am looking for as much information as possible.
When I bought the boat, I knew the trailer was crap, but I wanted the boat, not the trailer.
Tell me, is the 200 Osprey a V-bottom, or a semi-V?
Keith
September 23, 2007, 11:33:51 PM
Re: Boat Trailer
« Reply #3 on: September 23, 2007, 11:33:51 PM »
Quote from: "KeithG"
Look up Champion Trailers in Slidell LA. I don't know how close that is to Lafayette? I have bought stainless u-bolts and such from them. They make aluminum I-beam trailers with galvanized axles. I don't have their trailer but they looked good on the web site and in their catalog.
www.championtrailers.com
Good Luck
September 23, 2007, 11:45:26 PM
damnitbadger
« Reply #4 on: September 23, 2007, 11:45:26 PM »
I've got a used "Float On" that my 222 CCP used to live on. I added a bracket to my boat so it's now a 25', the trailer was marginally to small and with the work needed I just decided to get a larger one. The trailer needs some axle work. It has a tandem torsion axle. It could be repaired or replaced. It's an Aluminum frame. Tires are in great shape. No brakes but it tows good. It was designed for a 20-23 footer. I was thinking about having the axles worked on or going to Champion in Slidel, La and getting a new spring axle set up. I'm in Mississippi.
Beware the lolipop of mediocrity, lick it once and you will suck forever!
88\' CCP 222 w/200 EFI Merc
September 24, 2007, 09:00:46 AM
KeithG
« Reply #5 on: September 24, 2007, 09:00:46 AM »
damnitbadger
Check your PM
September 24, 2007, 02:45:26 PM
KeithG
Re: Boat Trailer
« Reply #6 on: September 24, 2007, 02:45:26 PM »
Quote from: "Capt. Bob"
Good Luck
They look real good, just was hoping not spend 3500.00 on a trailer, but I might have to, so I appreciate the info.
Keith
September 25, 2007, 07:51:49 PM
KeithG
« Reply #7 on: September 25, 2007, 07:51:49 PM »
Just wanted to shout out to damnitbadger for meetng with me today about the trailer he has sale, I really apreciate it.
I am currently sitting in my motel room and trying to see if I can make it come in to my budget.
Keith
September 28, 2007, 05:56:36 PM
KeithG
« Reply #8 on: September 28, 2007, 05:56:36 PM »
O.K.  Guys speak now or forever hold your peace...
I believe I am going to let FASTLOADER build me a new trailer.
They have a 4200lb GVW single axle all aluminum with torsion springs that I believe will fit the bill.
Their price and delivery are within the budget.
Lets hear those Pros/Cons
Keith
September 28, 2007, 06:00:59 PM
The Bear
    • http://www.BearPawsWeather.com
« Reply #9 on: September 28, 2007, 06:00:59 PM »
How much did damnitbadger want for his? His looked in pretty good shape to me.
September 29, 2007, 07:05:26 AM
« Reply #10 on: September 29, 2007, 07:05:26 AM »
If you have the budget, I agree with JJ - go with the RollsAxle - guaranteed for life.  I put one of their axles under my 170 and when the time comes, I'll replace the 2 axles under my 230 with theirs too.
September 29, 2007, 08:51:21 AM
KeithG
« Reply #11 on: September 29, 2007, 08:51:21 AM »
Quote from: "The Bear"
Send him a PM.  I know he would like to sell it.  It just was not the trailer for me.
