Flatback 22-2 Rebuilds
1971 222 Flatback Rebuild (Tampa) FINALLY FINISHED PICS!!!!
Topic: 1971 222 Flatback Rebuild (Tampa) FINALLY FINISHED PICS!!!! (Read 11918 times)
September 13, 2007, 01:36:33 PM
Read 11918 times
wiler55
September 13, 2007, 01:36:33 PM »
I am extatic on starting my first complete rebuild. I hope that the wealth of knowledge in this sites members is ready to build a work of art. I will have the pics up on SUN. hope you all are ready to answer a ton of questions!
September 13, 2007, 02:28:53 PM
September 13, 2007, 02:28:53 PM »
Shoot anytime you're ready...
September 13, 2007, 06:15:48 PM
September 13, 2007, 06:15:48 PM »
I'm good for a small portion of the ton
September 15, 2007, 08:17:14 AM
aqua70
rebuild
September 15, 2007, 08:17:14 AM »
You are on the right web site for help.
These guys can give you step by step instructions!
They helped us out on our project
September 15, 2007, 07:12:03 PM
wiler55
September 15, 2007, 07:12:03 PM »
she will be in the garage in the morning just bought it from captjfran im sure you have seen his pics of the boat he was selling.
any ideas on what to put her on so that she is movable in and out the garage. any kind of dolly or wheel system that i can build so that she is somewhat movable. the garage is wide enough but not deep enough. so will have to put her in at an angle and then move her around. any ideas will help trust me!
September 15, 2007, 07:39:57 PM
September 15, 2007, 07:39:57 PM »
Good stuff.
Try this for a dolly:
http://classicmako.com/forum/topic.asp?TOPIC_ID=17824
September 16, 2007, 03:10:05 PM
wiler55
September 16, 2007, 03:10:05 PM »
thanks lil richard got her in the garage and she is on blocks.
now where do i start? all the stringers are in except where the gas tank is going to be.
should i start there how many holes should i cut for the gas tank and how far up should the tank be?
September 16, 2007, 06:59:27 PM
wiler55
September 16, 2007, 06:59:27 PM »
here is what the inside looks like
another view
and the gas tank
September 16, 2007, 10:00:19 PM
Undertow2
September 16, 2007, 10:00:19 PM »
wiler55 -
Almost bought that from Jim myself. Good call. I wasn't looking for one with the liner totally out. Hopefully you got that trailer from him. Nice trailer with guides and all...sweet deal.
September 17, 2007, 06:53:42 PM
wiler55
Reply #9 on:
September 17, 2007, 06:53:42 PM »
Where do i even start? i have no clue. im new to this. THis is my first rebuild and need your guys help!
September 17, 2007, 10:32:42 PM
Reply #10 on:
September 17, 2007, 10:32:42 PM »
Wiler-
Where are you located?
How much glass experience do you have?
I would start by getting a tank coffin setup... meaning installing the bulkheads for the tank. Then you will need to run the remaining bulkheads. From there you will want to get the rigging tubes setup, then comes the floor.
I can walk you through some thoughts (my opinions) if you'd like.
September 18, 2007, 12:36:48 AM
wiler55
Reply #11 on:
September 18, 2007, 12:36:48 AM »
i would love for you to run me through everything!
i live in tampa palms off bruce be downs and I 75.
I have a roll of 1808 and am gong to the fiberglass shop this week either poly or fiberglass coatings.
what should i get as far as resin, more sheets and accessories so that i will have the material to glass, fillet, fill, material for the extra stringers in the middle ect....
What is the difference between the white sole material that has plastic pockets and is very light weight and heaver material like capt rick used on his sole.
I was thinking of using the heaver more solid floor to prevent soft spots in the future and so that i would not have to cut anything out and put in other material for rigging such as the tower.
September 18, 2007, 12:39:47 AM
wiler55
Reply #12 on:
September 18, 2007, 12:39:47 AM »
as far as glassing experience i just fixed a hole in my brothers boat and it is very strong and looks great. glassing is not the problem its the smaller things like mixing the fillet mixture cause i dont know what goes in it. or homemade fairing compound with cilica and wood flour i have seen these used on other peoples restoration but i have no clue what is used when
September 18, 2007, 07:56:02 AM
Reply #13 on:
September 18, 2007, 07:56:02 AM »
Ok, I will try to answer everything...
First, find out what was used on the boat to begin with... I think Jim was using either Polyester resin or vinylester... as long as it was not epoxy, you can put poly over it. I normally use general purpose layup resin (GP). It can be bought at FGCI for about $125 a pail.
As far as sole material, the "light stuff" you're referring to is nidacore... it's a honeycomb. It is fine to use, but you have to put backers (or backfill) the material everywhere you mount a fastener to it. What Capt Rick used is Penske board, which is nearly identical to Coosa board. It's basically a foam / fiberglass sandwich and has good screw retention. They are both good choices, and both have their positives. I would personally go with penske if I was going the composite route.
For what else you will need, all I can do is tell you what I keep around:
- a roll of 1.5oz mat (for surface work... negates "print through"
- a roll of 1808 XM
- a roll of 2415 stitchmat
- a box of cabosil (10 lb I think- big box)
- a box of milled fibers
- a slew of rollers, brushes for applying resin
- a few metal ribbed rollers to work out air bubbles
- a 7" heavy duty grinder (to use with fiber disks)
- a 3.5" grinder for smaller work
- a small assortment of air tools including a DA sander and an inline sander
That will get you well on your way. Once again, these are just the tools and materials in my kit... tailor your own tools to your needs.
I am in forest hills... so sometime swing by and we can chat further. PM me.
September 18, 2007, 09:05:41 PM
wiler55
Reply #14 on:
September 18, 2007, 09:05:41 PM »
from these pics what is the tube that is comming out the gas tank about a foot? and does it matter if is points twards the bow or the stern?
