Author Topic: Hydraulic Steering System troubleshooting  (Read 1291 times)
September 13, 2007, 07:30:35 AM
Read 1291 times
« on: September 13, 2007, 07:30:35 AM »
This was posted by GoneFission: Thanks John
Here's some info from Boating and Fishing Inc.
6240 105th Terrace North Pinellas Park, FL 33782
Telephone: 727-546-7257 Fax: 727-768-0099
E-mail: http://www.boaterscatalolg.com
http://www.fishing-catalog.com
Steps to troubleshoot hydraulic steering problems:
If your steering is harder than you think it should be.
Remember that unless you have a power-assist steering pump that is attached to the engine (like your car), you do not have power steering, simply hydraulic steering. Hydraulic steering generally makes turning the steering wheel much easier than manual steering, but it is almost never ‘one finger’ steering. Most vessels under 35 feet in length will not have power-assist. If you just purchased this vessel, try to ascertain from the previous owner whether the steering was always hard or if this is a new problem.
If you have owned this vessel since it was new and the steering has gotten
harder over time, go through the following steps:
1. Make certain that there are no kinks in the hoses of your steering system
2. Make sure you have a full reservoir of fluid.
3. Remove the bolt(s) that attach the steering cylinder to your engine,
outdrive, or rudder and attempt to turn your engine, outdrive, or rudder by hand. If it moves freely, turn the steering wheel and see if it is still hard to turn.
4. If the wheel turns very easily at this point and your engine, outdrive, or
rudder also turns very easily, Lube all the fittings on the engine, outdrive,
or rudder as preventative maintenance and re-attach the cylinder.
5. If the wheel is still hard to turn, even with no forward or reverse motion of the vessel and the engine out of gear, call us at 800-745-0765
If you turn the wheel and the engine, outdrive, or rudder turns slowly,
only partway, or only in one direction: probably your cylinder needs to be
service and re-sealed. Call us at 800-745-0765.
If your steering is slow or ‘mushy’: You probably have air in the system.
Consult your owner’s manual for bleed instructions.
You have a leak around the helm shaft behind the steering wheel: Your
helm needs to be serviced and re-sealed. STOP! This is not a do-it-yourself job! Unless you are experienced at hydraulic repairs and specifically familiar with the inner workings of your brand of helm, we do not recommend that you attempt repairs in the field. Call us at 800-745-0765. Small leaks won’t prevent your system from operating as long as you keep the reservoir topped up with fluid, but you should not operate this way any longer than necessary to get back to port.
Bumpy helm operation, or if the wheel feels like it is jumping as you turn
it: This can indicate air in the system. Try bleeding the system first. If this
does not change it, there is probably trash in one of the check valves in the helm. This is not a do-it-yourself job. Call 800-745-0765
If your boat drifts off course even though you are not changing the
steering wheel or rudder angle: You may have a check valve in the helm
that needs servicing or the cylinder needs servicing or both.
If you have a three line system with a separate reservoir and the
pressure drops regularly:
1. Check for leaks throughout the system. Be sure to carefully check for
indications of oil around the cylinder and the back and top of the helm
as well as around the reservoir. Check every area of the vessel where
the hydraulic hoses run, particularly where they go through bulkheads
or around corners.
2. If there are no visible leaks, mix a teaspoon of dish soap in a gallon of
water and pump up your system to 30 pounds. Put some of the soapy
water on the top of the reservoir, around the gauge, fill cap, and pump
on the top of the reservoir and watch for bubbles. If bubbles are seen
around any of the fittings, thoroughly clean the top of the unit, then
after drying it , remove the part that has the leak around it. You might
try carefully wrapping the threads with Teflon tape and screwing it back
in or call us for a replacement part or reservoir as needed.
_________________
200 Mercury Black Max
