Author Topic: 22-2CCP gas tank specs  (Read 1611 times)
September 10, 2007, 01:29:58 PM
Read 1611 times
« on: September 10, 2007, 01:29:58 PM »
I think I will be replacing the gas tank on my 22-2CCP this fall.  I would like to be able to order and receive a new tank before I take the console off and get the old tank out.  The idea is a quick out, quick in process.   :wink:
However, when I recored the section over the tank, I did not measure the tank - duh  :roll:  - what was I not thinking...
Does anyone have the specs for the 22 foot CCP gas tank?  Anybody measured the inside of the tank tub?  It would really help if someone in the middle of a rebuild and can provide the tank tub measurements.
Thanks!
September 10, 2007, 02:10:29 PM
« Reply #1 on: September 10, 2007, 02:10:29 PM »
You might try RDS manufacturing in Perry, FL... they manufactured quite a bit of OEM tanks in the 70s-80s... I know they had an Osprey tank drawing on file.
September 11, 2007, 05:13:31 PM
Time to do it!
« Reply #2 on: September 11, 2007, 05:13:31 PM »
I just went from "considering" to "gotta do - now!"  :shock:
Tank just started leaking when full.  Drained it down to where it's not draining through the transom drain, but tank replacement is now priority 1 on the boat.  Got a big fishing trip scheduled in 3 weeks, so I need to have it done by then.   :!:
Does ANYONE have the specs for the 85 gallon Aquasport tank?  It was used on the 22 foot CCPs and the 22 foot Family Fisherman.  I would like to get the new tank started ASAP, and it will take a day or so to get the console, seat, and center cover out so I can get to the tank.   :wink:
Thanks for any info you can provide!
September 11, 2007, 06:29:04 PM
« Reply #3 on: September 11, 2007, 06:29:04 PM »
All I can think of if you can't find the specs., is to try calling:
http://www.alloymetalworks.com
or
http://www.lutherswelding.com/
They might have the size on file.
September 11, 2007, 06:36:44 PM
« Reply #4 on: September 11, 2007, 06:36:44 PM »
One other thing to check before pulling the tank... when you open her up you may find the filler or vent hoses have cracked & failed.  This ethanol cocktail they're peddling as gasoline nowadays disintegrates the older hoses into mush.  I found that out on my '74 22-2.
September 11, 2007, 08:45:28 PM
Leaks
« Reply #5 on: September 11, 2007, 08:45:28 PM »
Yep, opened the port and put the scope inside - no leaks on the topside.  Looks like the leak is on one of the sides of the tank.  Couldn't see it with the borescope, but also did not spend the time and effort to do a 100% inspection - not like it's a nuke plant - I'll just replace the tank and be back in biz...   Order on the way for Alloy!
Thanks for the feedback and suggestions!!!
September 11, 2007, 08:50:41 PM
« Reply #6 on: September 11, 2007, 08:50:41 PM »
Alloy had the specs.?
September 11, 2007, 10:19:37 PM
Tank
« Reply #7 on: September 11, 2007, 10:19:37 PM »
No, but I talked with the OEM, Florida Marine Tanks.  They had the drawing for the 85 gallon Aquasport tank, but have a 4 week delivery, which won't work for me - got  a big fishing trip in mid-October.  I tried to find a way to cut the time, but they are stuck on 4 weeks.  :cry:
Anyway, between talking with them, getting the measurements from jdupree on his 200CCP, and carefully reviewing photos I took when I recored the cover, I was able to come up with what seemed to be the correct measurements.  The folks are Florida Marine Tanks were nice, but were not ready to just send me their drawing so I could get my tank fabricated somewhere else...  :roll:
When I ran the specs through the calculator, the volume came up at - this is the good part - 85.2 gallons!  That confirmed it, so the order is on the way to Alloy.  5 days for fabrication and 3 days shipping and I'm in business again!   :lol:
September 11, 2007, 10:36:11 PM
« Reply #8 on: September 11, 2007, 10:36:11 PM »
Have heard very good things about Alloy... also about Luther's.  When the time comes, Luther's will be doing the two tanks for the 240 and even offered to deliver them.
Please post pictures of the operation when you get into it.
October 05, 2007, 02:55:05 PM
PrettyWork
tank specs
« Reply #9 on: October 05, 2007, 02:55:05 PM »
I just replaced mine...but don't have the measurements. Will try to get them from the shop. I did see the area when the deck was up...after the new tank was in. Biggest disapointment...;there was a good bit of extra space towards the bow....and I could have gotten an easy 100 gal plus had I known.
October 08, 2007, 05:46:58 PM
BOB DOC
Re: Time to do it!
« Reply #10 on: October 08, 2007, 05:46:58 PM »
Geeze, I'm awfully glad I was not the one who triggered this tank replacement thing for you.
I sure do appreciate your replies and direction and the pictures on the project will be invaluable if I Need to go ther too. I should find out this weekend when we go get it and bring it home to Chattanooga. I'll let you know. Again thanks., Bob Doc
Quote from: "GoneFission"
Sláinte, 1980 246 AQUASPORT FAMILY FISHERMAN
1990 YAMAHA 150 SALTWATER SERIES HEADED TO CALIF.
