Author Topic: Garmin GPSMAP440s  (Read 1480 times)
August 30, 2007, 09:22:17 AM
Read 1480 times
KeithG
Garmin GPSMAP440s
« on: August 30, 2007, 09:22:17 AM »
Just got my new GPS, while reading the instructions, they suggest mounting the antenna on the bow as opposed to the top of the T-Top.
Has anybody else done this?
Can the antenna cable be spliced?  It is going to be a bear to fish that cable end thru my T-Top.
Keith G
August 30, 2007, 10:14:39 AM
« Reply #1 on: August 30, 2007, 10:14:39 AM »
Mounting the antenna on the T-top would be fine.  No idea why Garmin suggests the bow.  The antenna only needs a clear line of sight to the sky.
August 30, 2007, 10:24:47 AM
KeithG
« Reply #2 on: August 30, 2007, 10:24:47 AM »
It actually says: "The unit provides more stable readings if it is located nearer to water level"
August 30, 2007, 10:27:02 AM
KeithG
« Reply #3 on: August 30, 2007, 10:27:02 AM »
Quote from: "JimCt"
I'm with you :D
Keith G
August 30, 2007, 10:41:35 AM
« Reply #4 on: August 30, 2007, 10:41:35 AM »
To give you a warm fuzzy feeling about the operation of the antenna on the T-top, why not just temporarily mount it up there with tape or something and see how it works?
August 30, 2007, 08:16:22 PM
GPS
« Reply #5 on: August 30, 2007, 08:16:22 PM »
I think you would lose more with a spliced cable and extra cable length than you might gain from the bow location.  Put it on the t-top or the top of the console and it will work fine.
August 31, 2007, 09:28:02 AM
KeithG
« Reply #6 on: August 31, 2007, 09:28:02 AM »
I put it on the T-Top...
Now I just have to figure out how to use it.
Keith G
September 04, 2007, 10:52:55 AM
DOCREED
« Reply #7 on: September 04, 2007, 10:52:55 AM »
Mount it on the T-top
89 250 CCP
full transom
September 04, 2007, 01:00:36 PM
« Reply #8 on: September 04, 2007, 01:00:36 PM »
The rocking of the boat causes erratic readings at slow speeds.  The higher the antenna is mounted, the worse the readings jump.  It's a downside to more accurate and faster calculating units.  They think the boat is jumping from side to side.
A good hand with a soldering iron can replace the connector.  I would not splice it.
September 05, 2007, 09:34:00 AM
DOCREED
« Reply #9 on: September 05, 2007, 09:34:00 AM »
I have installed hundreds of GPS antennas on T-Tops and never had a problem.
89 250 CCP
full transom
