Livewell
Topic: Livewell (Read 3603 times)
August 29, 2007, 05:53:49 PM
Read 3603 times
MARINEWITHABOAT
Livewell
August 29, 2007, 05:53:49 PM »
Hi, new here and have a few questions.
I just bought a 1987 17' Aquasport. In front of the Console there is a livewell/seat. The previous owner tore outeverything. Now I have two holes along the top one hole near the bottom and the drain hole that lets it drain down the side of the boat. My question is what is the easiest way to go about installing a livewell pump. I've looked around the access panels and pulling a tube through the hull of this boat is going to be a challenge. Not to mention I dont have a thru hull allready. Would a transom mounted pump be the easiest solution and just run the water hose inside the cavity on the starboad side that has the steering and throttle cables up to the bottom hole. My thinking is the top to holes in the baitwell were for lights? Also I want to find a way to put a t fitting on the livewell pump so that it serves as a saltwater wash down. Any tips or advice from previous installs would be awesome. At the moment I have two pumps and thats about it. Thanks again for the help I'll try and include a picture later.
Semper Fi,
Jeff
August 29, 2007, 06:18:42 PM
MARINEWITHABOAT
August 29, 2007, 06:18:42 PM »
Console
Livewell Location
My Baby
Going to get a picture of all those holes now.
Semper Fi,
Jeff
August 29, 2007, 06:27:33 PM
MARINEWITHABOAT
August 29, 2007, 06:27:33 PM »
Holes As Looking Through Console
No Thru-hull on Transom
As Seen From Inside Livewell
Semper Fi,
Jeff
August 29, 2007, 06:30:00 PM
MARINEWITHABOAT
August 29, 2007, 06:30:00 PM »
PS
What do you think of the paint and decal
Semper Fi,
Jeff
August 29, 2007, 06:43:44 PM
KeithG
August 29, 2007, 06:43:44 PM »
Very nice looking vessel
That live well is like mine, the pump that was in there was for recirculating the water only, you would have to bail water to fill it up and the drain... well it just drains on the deck.
KeithG
August 29, 2007, 07:01:46 PM
MARINEWITHABOAT
August 29, 2007, 07:01:46 PM »
Thanks Man, so what would you do to replace the console doors if at all? Also thinking about installing a saltwater washdown any ideas on good placement?
Semper Fi,
Jeff
August 29, 2007, 08:43:05 PM
August 29, 2007, 08:43:05 PM »
Welcome Aboard
Nice looking boat. Nice color paint - badge looks good too.
The only thing leading up to the console is the trough to starboard? They didn't put any tubing in by that year? My '71 has the same trough then
If you do a search on "livewell" or "pumps" you'll probably come up with a few topics covering what you're asking - I remember several people having transom mounted pumps.
As for the console doors, try Star Board. That would look fine and function well too.
August 29, 2007, 09:26:14 PM
August 29, 2007, 09:26:14 PM »
You can find almost anything for rigging a live well here:
http://www.livebaitlarry.com/
They make a 3-way valve for switching the water supply lines, even one with a remote control cable.
http://www.westmarine.com/webapp/wcs/st ... SiteSearch
August 29, 2007, 09:26:18 PM
August 29, 2007, 09:26:18 PM »
Welcome!!!
Whoever did the paintwork & badge did a great job. Can you get back in touch with the old owner and see what the deal was with the livewell set-up? Seems odd to have taken out the plumbing.
August 29, 2007, 10:06:37 PM
beast819
Guest
Reply #9 on:
August 29, 2007, 10:06:37 PM »
I like that color and badging. Anyone know where I could get that badge??? Maybe in black or a teal?
August 29, 2007, 10:22:43 PM
Reply #10 on:
August 29, 2007, 10:22:43 PM »
Quote
The marine surplus joint (Marine Liquidators?) down in fort pierce FL has them...
August 30, 2007, 05:06:51 AM
Reply #11 on:
August 30, 2007, 05:06:51 AM »
http://cgi.ebay.com/ebaymotors/AQUASPORT-AQUA-SPORT-Decal-for-your-boat-or-car-18_W0QQcmdZViewItemQQcategoryZ50443QQihZ001QQitemZ110161106612QQrdZ1QQsspagenameZWDVW
August 30, 2007, 09:36:44 AM
beast819
Guest
Reply #12 on:
August 30, 2007, 09:36:44 AM »
thanks Rick and lilRichard.
August 30, 2007, 01:19:57 PM
MARINEWITHABOAT
Reply #13 on:
August 30, 2007, 01:19:57 PM »
so star board for the doors on the console? is that pretty easy to cutt? Anyone know any back draws to using plexiglass instead?
Semper Fi,
Jeff
August 30, 2007, 01:40:17 PM
Reply #14 on:
August 30, 2007, 01:40:17 PM »
Plexi can be brittle, and it is not machinable like starboard. Starboard can be drilled, cut and routed.... not so with Plexi (not easily at least)
Livewell
