Author Topic: Marine Mechanic or Surveyor to check the engine?  (Read 566 times)
August 28, 2007, 09:42:22 AM
Read 566 times
doyle007
« on: August 28, 2007, 09:42:22 AM »
Guys,
I've put a deposit on a 1983 AS196, which has a '98 Mercury 135 2-stroke on it.  I want to get the engine checked to make sure that it's going to run for a few years.
I called a bunch of marinas yesterday near where the boat is located (about an hour north of me), and left a lot of voicemails (most Marinas are apparently closed on Monday). I just received a call back from one of them, and they say that they don't really check over engines to see if it should be sold, but the service manager suggested that I have a marine surveyor inspect the engine.
Now, the places that I called are all listed on the Mercury website as dealers and service partners, so I'm thinking that a certified Mercury mechanice would be the best person to look it over.  I was kind of surprised when a service manager said that I should get a surveyor instead.  I did speak to a couple of places yesterday, and they said that they don't do that kind of service (they just do rebuilds, fixing, etc.)
So, what do you all think?  I did find a place that will check the compression, gear oil, etc. to see if I'm buying something that will last for a few years, or if the engine is a dog.  I'm just wondering if I should get a surveyor to check it instead of a mechanic.
By the way, I would like to thank RickK for all of his help.  I've been emailing some questions to him, and he's provided me with a great deal of information.  Thanks Rick.
August 28, 2007, 10:28:38 AM
beast819
« Reply #1 on: August 28, 2007, 10:28:38 AM »
doyle,
IMO I would highly recommend getting yourself a certified marine surveyor because it is their job to inspect every inch of that boat, test the engine thoroughly, and report back to you with their honest opinions.
I was just in your shoes about a month ago and the guy I found was awesome. He did a top to bottom inspection, checked the compression, gear oil, etc.. and also took the boat on a sea trial to insure it indeed ran. After his evaluation and documentation stating what he thought the boats value was it was a no brainer in my decision to purchase the boat.
Of course you must take the boat on a sea trial yourself before purchasing any boat.
Where is the boat you are looking to purchase located?
August 28, 2007, 10:37:09 AM
« Reply #2 on: August 28, 2007, 10:37:09 AM »
I don't know your exact location but here is a reputable surveyor in S. Jersey.  If it's too far, maybe he knows someone in your area.
Send him an Instant Message from this link.
http://outdoorsbest.zeroforum.com/zerou ... le&id=7772
August 28, 2007, 12:02:46 PM
« Reply #3 on: August 28, 2007, 12:02:46 PM »
Likely the surveyor would have a mechanic check the engine.  Basic compression test, lower unit lube oil check for water and a test of the engine in operation on the boat (sea trial) should be all you need.  If yo do buy the rig, have the fuel filter and water pump replaced.
August 28, 2007, 01:44:01 PM
ralpht44
« Reply #4 on: August 28, 2007, 01:44:01 PM »
A surveyor is the way to go if you are not overly knowledgeable yourself. You would be amazed at the stuff they find. I can recommend a good surveyor in the south jersey area if your interested.
