Engines & engine woes
Instrumentation Question?
Topic: Instrumentation Question? (Read 2439 times)
August 20, 2007, 09:49:13 AM
Read 2439 times
Mad Dog
August 20, 2007, 09:49:13 AM »
This is my first post to this forum. I am amazed at the popularity of the Aquasport line. When I picked up my 222 project off E-Bay I had no idea there would be so much support available.
My project boat has an OEM console that I am restoring first (to get a little practice). My 222 is rigged for an outboard and I intend to keep it that way. Here is my question, what instruments should I plan to install in the CC instrument panel? Of course I will need a tach and electric fuel gauge. Are there any other "must have" or "nice to have" instrument?
When finished setting up I plan to a GPS and depth finder, so a speedometer is not necessary.
Thanks for any input.
http://s175.photobucket.com/albums/w150 ... Aquasport/
August 20, 2007, 10:16:42 AM
KeithG
August 20, 2007, 10:16:42 AM »
I too, am slowly rebuilding my instrument panel, and like you, I am planning on doing away with my speedometer also, I just repaired my fuel gauge this weekend, and am waiting on delivery of my new tach, you might want to consider a volt meter and or battery status gauge
August 20, 2007, 11:53:09 AM
JimCt
August 20, 2007, 11:53:09 AM »
This is how I did mine for my 240:
JimCT
\'74 22-2 inboard
HIN:ASPL0953M74J
Chrysler 318
\'74 Marshall 22
August 20, 2007, 12:40:27 PM
KeithG
August 20, 2007, 12:40:27 PM »
SWEEEETTT
August 20, 2007, 01:21:06 PM
gw204
August 20, 2007, 01:21:06 PM »
Here's some shots of the panel I made for my old 204 Grady...
Top row, left to right: tach, speedo, trim, volt, 12-V receptacle
Bottom row, left to right: ignition switch, Navman fuel flow meter, fuel, water pressure, temp, hourmeter
Brian
St. Leonard, MD
1981 Mako 17
1986 Grady White 227
August 20, 2007, 01:26:23 PM
August 20, 2007, 01:26:23 PM »
trim
volts
water pressure
motor temp
fuel
August 20, 2007, 03:57:59 PM
RebelYell
August 20, 2007, 03:57:59 PM »
Recently, I replaced the instrument gauge panel and switch panel bezels with starboard polymer on my 1990 Osprey 200.
Instrument Gauges:
Did away with Trim. Don't need it; I prefer to look back and see my engine trim anyway.....I have Tach, Engine Temp, Fuel and Battery Voltage. That's it. Keep it simple. Disconnected worthless Speedometer ( have GPS )
Switch Panel:
Went to local marina and got a six switch panel for about $ 25.00. Also added 2 X 12 V receptacles to the starboard polymer bezel and wired them in parallel. Have switches for Bilge, Navigation Lights, Cock Pit Lights, Running Lights, Livewell, and Accessory ( 12V receptacles ).
That's it and that's all my old boat needs. I had to rewire THE ENTIRE 12V system and am pleased with the results. I kept things simple on purpose.
RebelYell - Winter Haven, FL
August 20, 2007, 06:19:04 PM
Mad Dog
August 20, 2007, 06:19:04 PM »
Good examples guys! Thanks for the input.
September 17, 2007, 04:29:12 PM
Max
Planned console rebuld
September 17, 2007, 04:29:12 PM »
I plan on doing a rebuild as a winter project. The console has so many holes I can't find a place to mount stuff. I wound up adding a piece of teak to the top to cover up the Swiss cheese effect temporarily.
I plan on:
Tach
Battery meter
Fuel
Water temp
Engine hours (the little oblong type to save space)
In-dash VHF (it's small enough)
I also will do a complete rewire job while the console is up on the bench in the basement. Soooooo much easier!
Max
Greg (Max) Maxwell
Fort Leonard Wood, MO
Federation of Fly Fishers Life Member
1986 Osprey 200 w/ 2000 Merc 115 & 5hp Nissan 4-stroke kicker
September 18, 2007, 05:47:16 PM
Gauges
September 18, 2007, 05:47:16 PM »
I would go with water pressure instead of temperature for an outboard. You can see an impeller going bad or something else before it happens with a water pressure gauge. You won't see overheating unitl it's too late!
September 18, 2007, 09:53:40 PM
Max
Water pressure gauge
September 18, 2007, 09:53:40 PM »
Thanks! There is one on the panel now but it's not functional. I'll keep my eyes open for a new one at Bass Pro.
Max
Greg (Max) Maxwell
September 19, 2007, 05:11:17 PM
BPS
September 19, 2007, 05:11:17 PM »
BPS got you covered:
http://www.basspro.com/webapp/wcs/store ... rchResults
September 20, 2007, 08:13:46 AM
Max
Bass Pro special
September 20, 2007, 08:13:46 AM »
Cap,
Thanks for the website. However, since I live only 80-plus miles from the "temple," I hit the clearance center regularly. It handles all the returns and overstocks from the entire chain. So far I've picked up a tach and a battery meter at aout 50% of normal price. The trick is whether or not the stuff is all in the same color. Even if I have to buy a couple I'll still e ahead of the game.
Max
Greg (Max) Maxwell
September 20, 2007, 06:05:46 PM
Temple
September 20, 2007, 06:05:46 PM »
Cool! Maybe I'll send you my wish list??!!
