Author Topic:  (Read 748 times)
August 19, 2007, 01:16:19 PM
Read 748 times
gw204
« on: August 19, 2007, 01:16:19 PM »
Have you tried jumping it with your car?  Also, what happens if you remove the spark plugs and hit the key?
There was an old 60 HP Evinrude on my 170 when I first got it that had the same symptoms.  On an old battery that came out of my Grady (registered 12+ V) it would spin slow and never really get full revolution.  I removed the plugs and when I hit the key it shot a bunch of old gas and oil out of the cylinders.  I then sprayed a little starting fluid in the cylinders, replaced the plugs, sprayed a little in the carbs and tried again.  This time it spun much better, but not as fast as it should.  Gave it a little help with my Jeep's charging system (jumper cables), sprayed bit more in the carbs and that did it.  She spun over nice and fast and roared to life.   :)
Brian
St. Leonard, MD
1981 Mako 17
1986 Grady White 227
August 19, 2007, 01:17:04 PM
gw204
« Reply #1 on: August 19, 2007, 01:17:04 PM »
If you get in a bind, I'de be more than willing to help you out after I move next weekend.   :)
Brian
St. Leonard, MD
1981 Mako 17
August 20, 2007, 11:45:32 AM
« Reply #2 on: August 20, 2007, 11:45:32 AM »
Possibly a bad solenoid.  With a volt meter, first confirm your ignition switch is operating properly.  If the switch is good, problem is in the solenoid.  Replace it and you should be good to go.
