Author Topic: Distributor rebuild needed  (Read 663 times)
August 13, 2007, 08:05:22 AM
Read 663 times
« on: August 13, 2007, 08:05:22 AM »
Anyone know of a shop that rebuilds marine distributors?  The mechanical advance on mine is seized with rust.
August 13, 2007, 10:04:25 PM
Distributor
« Reply #1 on: August 13, 2007, 10:04:25 PM »
It's not hard to fix that, and you may want to go ahead and update to an electronic system.  There is a neat kit that fits inside the distributor and replaces the points and condenser with a much improved electronic setup.  You can get the weights and springs for the mechanical advance at NAPA - just make sure you know the distributor model - or take it in...   Prestolite?
Check these out:
http://www.articleinsider.com/article/224466
http://pertronix.com/new_products/ignit ... g_pg34.htm
http://i-netmarine.com/elecig.htm
Or just pick up a new one on eBay for $20 or so...
http://search.ebay.com/search/search.dl ... category0=
Good luck!
August 13, 2007, 10:39:37 PM
« Reply #2 on: August 13, 2007, 10:39:37 PM »
Thanks for the info. GF.
Had a bear of a time finding parts, which I finally gave up on, for the original distributor (circa 1982) which was electronic with an external ECU, so I figured the hell with it and bought a new Mallory distributor with the ECU built right in.  Double element ballast is replaced with a single element and a fair amount of engine harness wiring goes away.  Problem rebuilding distributors is calibrating the advance curve.  If the curve's off, performance & efficiency go out the window. With this new system everything's now current production.
