Engines & engine woes
Johnson 110 VRO V4 Year?? Ser No??
Topic: Johnson 110 VRO V4 Year?? Ser No?? (Read 2927 times)
July 20, 2007, 10:06:04 AM
Read 2927 times
MJB
July 20, 2007, 10:06:04 AM »
Anyone know where there is a plate or serial no. on this motor or how I can identify the year?? I'll likely see if anyone is interested in the parts since it is siezed.
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
July 20, 2007, 10:13:27 AM
jdupree
July 20, 2007, 10:13:27 AM »
Mike,
Judging by the cover, I think it will be a 1987 or 1988. My 90HP looked just like that one. If I am not mistaken, the plate should be on the motor mount not on the leg of the motor.
John L. Dupree, III
AQABLA84E999
Member #257
July 20, 2007, 11:44:04 AM
July 20, 2007, 11:44:04 AM »
I agree, mine was a '86 and looked identical. Tag should be on the mount, possibly painted over.
July 20, 2007, 12:16:44 PM
MJB
July 20, 2007, 12:16:44 PM »
Any idea if the tag would be on the left or right front or back??
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
July 20, 2007, 02:19:49 PM
jdupree
July 20, 2007, 02:19:49 PM »
I think that if you are standing behind the boat looking at the motor it should be on the port (left) side. It should be right in the middle of the mount. It should not be hard to find so it might be missing
John L. Dupree, III
AQABLA84E999
Member #257
July 20, 2007, 02:22:46 PM
jdupree
July 20, 2007, 02:22:46 PM »
Mike,
Have you figured out which is bad - lower unit, power head, or both
John L. Dupree, III
AQABLA84E999
Member #257
July 20, 2007, 04:50:26 PM
MJB
July 20, 2007, 04:50:26 PM »
jdupree,
I'd say the tag must be missing. I've looked all over the motor and can't find anything that would resemble serial numbers.
Only the powerhead is siezed, I can spin the prop freely so I think the lower unit is still good.
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
July 20, 2007, 10:31:09 PM
JimCt
July 20, 2007, 10:31:09 PM »
A seized power head may not necessarily mean the powerhead's bad. It all hinges on how the engine seized. If it threw a rod, or had some other big mechanical "adventure", then it's done. If, however, the engine's seized from simply sitting, that may be a different story. If the previous owner used the engine with no problems and shut it down in that condition, very likely there may be just a thin film of rust in the cylinders stopping the parade.
In the name of science, try spraying a
heavy
dose of PB Blaster
www.blasterchemical.com/store/moreinfo.cfm?Product_ID=1
in each cylinder and do this every other day for a week. Try turning the flywheel after a week. If no luck, using a short block of wood as a cushion give the flywheel gear teeth a few good knocks in either direction of rotation with a dead-blow hammer; don't be shy, wail on it... If luck is with you, you may get it freed-up. I ran this magic on an old 6hp kicker engine with good results.
JimCT
\'74 22-2 inboard
HIN:ASPL0953M74J
Chrysler 318
\'74 Marshall 22
August 09, 2007, 03:29:48 PM
MJB
August 09, 2007, 03:29:48 PM »
JimCt,
Update on the PBBlaster method -- used almost the whole can in the past week or so and still no luck. Tried the block of wood/hammer method and still does not budge. I'm going to try one more time this weekend and see what happens.
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
August 09, 2007, 04:43:18 PM
JimCt
August 09, 2007, 04:43:18 PM »
Certainly worth the effort. Good luck!
JimCT
\'74 22-2 inboard
HIN:ASPL0953M74J
Chrysler 318
\'74 Marshall 22
September 19, 2007, 09:16:13 PM
gmcjohnny
September 19, 2007, 09:16:13 PM »
instead of hitting the flywheel put a socket on the flywheel nut with a breaker bar an try to free it up that way ,did you take the lower unit off yet i had one where i could spin prop shaft but main shaft going to power head was locked up on top of one of the heads you might see a small freeze out plug sometimes theres #'s on that if you bring them to a good omc shop they can run the serial # for you johnny
September 20, 2007, 12:07:43 PM
Bygracealone
September 20, 2007, 12:07:43 PM »
MJB,
If you look on the engine block, you should find something that looks like a freeze plug. If you look closely, you'll see some numbers on it. Write those numbers down and go to this site to decipher the numbers:
http://www.warnersdock.com/Modelyearlookup.htm
September 21, 2007, 11:29:39 AM
MJB
September 21, 2007, 11:29:39 AM »
I'll look for the freeze plug and the numbers, thanks for the website info.
I had not pulled the lower unit, I'll try that and see if that shaft is what is/was binding.
Thanks.
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
