Author Topic: What is the weight?  (Read 1329 times)
July 02, 2007, 04:06:24 PM
Read 1329 times
Terrapin Flyer
What is the weight?
« on: July 02, 2007, 04:06:24 PM »
I recently broke the axle on my Aquasport's trailer.  I am the third owner and do not have any specifications regarding the weight.  It is a 1985 20' CCP center console with a 225 Johnson O/B.  Although the tank is rarely full it does hold 73 gallons.  If anyone has a close idea it would be great. Thanks. Chris
August 30, 2007, 04:36:41 PM
scuppers
  • REGISTERED
« Reply #1 on: August 30, 2007, 04:36:41 PM »
I think gasoline weights around 6lbs/gal x 73= thats 438 lbs. with full tank. I have no idea how much your outboard weights, however the description of your boat doesn't jive with the cataloge. There are no 20' CCP the 222 is the first CCp in my cataloge it holds 85 gal. & weights 2200 lbs dry weight. The 20' Osprey  holds 45 gal. & weights 1550 lbs dry weight. My best guess on your outboard motor is probably 500 lbs. hope this was helpful. Scuppers :?
August 30, 2007, 06:32:11 PM
« Reply #2 on: August 30, 2007, 06:32:11 PM »
Quote from: "scuppers"
There are no 20' CCP the 222 is the first CCp in my cataloge...
Hey Scuppers, before you get too far:
August 30, 2007, 08:13:18 PM
« Reply #3 on: August 30, 2007, 08:13:18 PM »
Here ya go:
200CCP hull:  1900 lbs
Fuel, 73 gallons, 450 lbs or so
Engine, 500 lbs
Gear, rigging, bait, fish, ice, beer, 500 lbs (maybe more, depends on beer load  :lol: )
So you are looking at a minimum of about 3300 lbs.
See ya on the water!
September 01, 2007, 04:52:43 PM
Terrapin Flyer
« Reply #4 on: September 01, 2007, 04:52:43 PM »
thankk you again for your help
