Jim was suggesting near the drain plug, because that is where a lot of transom issues begin. I would suggest a few samples from around the transom (near other thru hulls, etc). When you're done- you need to fill the holes correctly with thickened resin to avoid making matters worse. If you need help with "how-to" we can give further details.
