Author Topic: Painting  (Read 1198 times)
June 01, 2007, 11:46:32 AM
Read 1198 times
DOCREED
Painting
« on: June 01, 2007, 11:46:32 AM »
I am considering painting my 250 CCP.  Does anyone have any ideas on how to remove all the graphics from the hull?  They are dried out and chipping anyway.
89 250 CCP
full transom
June 01, 2007, 12:04:29 PM
« Reply #1 on: June 01, 2007, 12:04:29 PM »
While your wife is elsewhere, gently apply heat from her hair dryer/blower.  Heat up a section and start peeling.  Adhesive may stay on the gelcoat which can be removed with acetone.
June 01, 2007, 11:32:50 PM
« Reply #2 on: June 01, 2007, 11:32:50 PM »
The one good thing I found out about "Peel-Away" stripper is that it does a wonderful job on removing vinyl decals even if it was marginal on paint.  Only has to be on for a few minutes and the decal bubbles right up.
June 02, 2007, 06:59:41 AM
« Reply #3 on: June 02, 2007, 06:59:41 AM »
I'll have to remember that about the peel-away when I replace the graphics on the 230.  I think I still have some it left.
June 02, 2007, 09:31:56 AM
Vinyl Graphics
« Reply #4 on: June 02, 2007, 09:31:56 AM »
Before using chemicals, try a razor blade scraper.  Old vinyl is usually hardened and often comes off pretty easily with a scraper.  Keep the angle close to the hull and take your time.  You can use chemicals, cleaners, or even some waxes to remove the residue.
