Author Topic: Do swamped AS float?  (Read 877 times)
May 29, 2007, 09:32:45 AM
Read 877 times
gcapehart
« on: May 29, 2007, 09:32:45 AM »
We have all seen the BW sawed and floating. The old AS literature on this site says they are unsinkable. Yes I remember the Titanic story. But is it theoretically unsinkable because of design with the amount of floatation or has anyone ever had such an occasion when awash she stayed afloat? Gary
ps: Yes it may be perceived as a dumb question. We do stay clear of the ledges in these parts. Even the locals(lobstermen, commercial fishermen)  here say, "Don't follow the locals up a harbor or anywhere, follow the bouys".
Maine25XF. Late to the gate we love our boat. Others are humbled by the Sally-Carol. We treat her like family, only better! If you have any tips, insights, or positions on the health benefits of two-stroke exhaust,  please opine and inform. Gary
May 29, 2007, 08:37:50 PM
Unsinkable?
« Reply #1 on: May 29, 2007, 08:37:50 PM »
The foam in the AS line is what makes them unsinkable.  Technically, any relatively modern boat is unsinkable, as the USCG makes the manufacturer test (really, an actual test) smaller boats with full capacity load, to not sink  when flooded with water.  Obviously this test does not apply to larger vessels, like ships...
If you own an AS with a hull liner, the space between the liner and the hull will be filled with foam.  If you have one without a hull liner, the space between the floor and the hull will be foam filled, sometimes with the area under the gunwales also foamed.  Here's the catch - if the foam under the floor is waterlogged - well, I would guess Davy Jone's Locker has a couple AS boats...
