Props
Prop question
Topic: Prop question (Read 615 times)
May 14, 2007, 10:47:18 AM
Read 615 times
Go Deep
Guest
Prop question
May 14, 2007, 10:47:18 AM »
I have an older 19'6 with a 125 hp engine. While I was able to get the boat on plane and up to 29 MPH (GPS), she was sluggish getting there. Is this a pitch problem? what should the prop pitch be? Thanks...
May 14, 2007, 08:41:35 PM
Mechanical Master
Speed
May 14, 2007, 08:41:35 PM »
What RPMs is the engine turning at top speed? What prop are you using (how many blades, diameter, and pitch)?
May 17, 2007, 05:18:59 PM
riverratjr
right prop
May 17, 2007, 05:18:59 PM »
I had to reprop my 150 hp blk max recently for use on my ccp 222. it was previously on a 18.5 ft Nitro lake boat. I had to go from a 4 blade 22" to a 15.5". I don't have the pitch # in my brain rt now. The key thing to do is determine your engine rated max rpm & prop to achieve that rpm at wide open throttle. Failure to do so will result in under or over rpm @ WOT, either of which can destroy your engine for different reasons. Sluggish out of the hole can usually be helped with max trim adjustments. I used a jack plate with 4 degrees of negative trim shims added to the top mtg bolts to 'tuck' the prop deeper under the stern. We were out last Tuesday, 4 people, 85 gal of fuel & several coolers of refreshments & ran 42 mph @ 6000 rpm on gps; 30-31 @ 4500 rpm & 8mph @ 2200 rpm. 10 gal/hr @ 6000 rpm & 5 gal/hr @ 2200 rpm. I love this hull/boat.
1991 ccp 222
Props
Prop question
