Bottom painting on trailer
Topic: Bottom painting on trailer (Read 1773 times)
May 10, 2007, 11:55:03 AM
Read 1773 times
ralpht44
May 10, 2007, 11:55:03 AM »
I just bought a 1987 222 Sandpiper with a trailer. I always kept the 19'6" family fish on blocks at the marina and had them paint it every year. The marina closed and I would rather do it myself anyway going forward. I assume I am going to have to jack one end of the boat up at a time or use multiple jacks to get it off the rollers. I have never done this before and figured I would ask the experts.
May 10, 2007, 02:21:46 PM
jdupree
May 10, 2007, 02:21:46 PM »
I did that with my 170. As you said, just use 2 or more jacks. Jack the boat up and move the trailer as far forward as you can then set her down. Just keep repeating the process. It is very time consuming but will work fine.
John L. Dupree, III
AQABLA84E999
Member #257
May 10, 2007, 11:42:01 PM
damnitbadger
May 10, 2007, 11:42:01 PM »
Lower your trailer jack all the way down and put blocks under the keel at the stern and 4x4s at each stern corner. Raise the jack as high as it will go and put blocks under the bow. Lower the jack about mid way. The boat should be clear of the trailer. Now let the air out of the tires. Cover the trailer with visqueen and paint the hull. You should have 4"-10" of clearance depending on your trailer.
Beware the lolipop of mediocrity, lick it once and you will suck forever!
88\' CCP 222 w/200 EFI Merc
May 11, 2007, 08:20:07 AM
jdupree
May 11, 2007, 08:20:07 AM »
I never thought of doing it that way. That would work but I just like the have the trailer out from under the boat so I have room to work. That is a good idea and I might try that when I paint the bottom on mine.
John L. Dupree, III
AQABLA84E999
Member #257
May 11, 2007, 09:28:02 AM
damnitbadger
May 11, 2007, 09:28:02 AM »
If your trailer is narrow enough you can put stands or blocks at the front corners and just pull the trailer out from under the boat. If I was moving the trailer completely out from under the boat I would use blocks at the rear corners as well. If not narrow enough, through a series of jacking maneuvers and blocks under the bow you can pull the trailer out, clearing the trailer cross members. This worked on my AS as well as a 28' sport fisher.
May 11, 2007, 09:45:55 AM
ralpht44
May 11, 2007, 09:45:55 AM »
All great suggestions guys. I think I have everything needed. Going to powerwash this evening and paint the bottom tomorrow and then in the drink she goes.
September 11, 2007, 02:38:58 PM
beast819
Guest
September 11, 2007, 02:38:58 PM »
post some photos if you can. I am interested in seeing the process.
Ant
September 11, 2007, 04:45:24 PM
Message
September 11, 2007, 04:45:24 PM »
jdupree: PM for you in your inbox. Thanks!
September 11, 2007, 06:16:57 PM
JimCt
September 11, 2007, 06:16:57 PM »
Be sure the blocking is
very
secure. If you are using wood blocks one on top of another, screw-shoot some 1 x 3's to the sides to hold them firmly together then cross brace...
Gotta keep things safe!
JimCT
\'74 22-2 inboard
HIN:ASPL0953M74J
Chrysler 318
\'74 Marshall 22
