Mask & goggles for grinding
Topic: Mask & goggles for grinding (Read 1710 times)
April 08, 2007, 06:01:39 PM
Read 1710 times
April 08, 2007, 06:01:39 PM »
Anybody have recommendations for a good mask & goggle combo for grinding? Goggles I'm using collect dust inside plus fog up so I have to stop every minute or so, take them off and wipe them out. They are the semi-soft type which contact skin all around to theoretically seal out dust which doesn't work worth a @#$%. Mask is the disposable paper type. Tried using Rain-X on the goggles but doesn't help much.
April 08, 2007, 08:04:42 PM
April 08, 2007, 08:04:42 PM »
I'm using a 3M respirator with disposable particulate filters... works well. I have no suggestions on goggles, mine suck too.
April 08, 2007, 08:27:00 PM
rburlington
Guest
April 08, 2007, 08:27:00 PM »
My mask is an AOSaftey purchased for $36.00 from Lowes. It works well and you can change the 2 filters according to the type of materials you are working with.
My goggles are hopeless; they steam up and allow some dust as well.
RGB
April 08, 2007, 09:06:57 PM
damnitbadger
April 08, 2007, 09:06:57 PM »
It's gross but if you spit on the inside lens and rub it around with a tissue till clear they won't fog any more. Works with a dive mask as well.
88\' CCP 222 w/200 EFI Merc
April 09, 2007, 08:48:51 AM
April 09, 2007, 08:48:51 AM »
Have tried spit, Rain-X, detergent, Downy dryer sheets & WD-40 with no luck.
April 09, 2007, 08:19:10 PM
April 09, 2007, 08:19:10 PM »
The only help I have found with goggles is a big fan. The neighbors replaced their central heat & air and I salvaged the big squirrel cage blower from the unit. I mounted it on a piece of plywood and put a long cord on it. I try to aim the fan where it's blowing most of the crap away from me. It does delay having to clean the goggles and helps the fogging also.
April 09, 2007, 08:42:36 PM
April 09, 2007, 08:42:36 PM »
Found these on Ebay & bought a pair.
Gov't. issue goggles good for sandstorms so they say. Look like regular garden-variety ski goggles to me. Will try a directed fan too & report results.
November 14, 2008, 10:58:12 PM
love2fish
November 14, 2008, 10:58:12 PM »
I used to use the wet wipes, like you get at a restaurant with wings or crab legs, to wipe the inside/outside of my ice hockey mask. If you clean the goggles, and then wipe the lens with the wet nap, let it kinda haze over, then lightly buff off the hazing with a tissue, it should keep the fogging down.
Chris
\'74 22-2
Member #921
November 20, 2008, 03:18:00 PM
MarshMarlowe196
November 20, 2008, 03:18:00 PM »
I actually bought some stuff in a bottle from a dive shop several years ago that was made to prevent fogging on dive goggles. Worked pretty good. I would check your local dive shop
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
