Author Topic: How Far Out in 19-6?  (Read 1250 times)
March 16, 2007, 08:19:13 AM
Read 1250 times
sturgeon
« on: March 16, 2007, 08:19:13 AM »
What is a safe distance to go out in the ocean/gulf in a 19-6:?:
I am mostly a coastal guy but figured a boat this size would be good for 10-15 miles out on the right day. :?:
Sturgeon
March 16, 2007, 10:48:55 AM
« Reply #1 on: March 16, 2007, 10:48:55 AM »
If you are confident of the weather and have a "buddy boat" go out with you, you should be OK.  Just keep in mind that sea & weather conditions can go to hell fast.
March 16, 2007, 11:13:36 AM
« Reply #2 on: March 16, 2007, 11:13:36 AM »
I've been out 10 miles in the 170 and it was ok until the fog set in  :shock:  - no fun after that, and the low freeboard makes me a little nervous too.  If I'm moving forward I don't worry, it's when I'm stopped that it can get fun (especially when a whale is around  :wink:  ).
March 16, 2007, 06:30:41 PM
« Reply #3 on: March 16, 2007, 06:30:41 PM »
I've been out 20 miles in the atlantic in my old 18 footer.but only in the summer when seas were 2-3 or less.Make sure your radio is in good order,and carry a handheld as a backup.Dont depend on your GPS make sure you keep a compass heading back to the inlet,Watch your fuel,one third out,one third to get back and one third in reserve.Use your GPS to plan your day,go to your furthest spot first and work your way back to your inlet.Remember if you are coming back against the wind and seas it will use more fuel.My 18 footer only had a 30 gal tank,you learn to keep an eye on your fuel gauge.Pick your day if its to rough stay inside,not worth it just to get beat up by rough seas.IMHO   8)
March 16, 2007, 07:05:21 PM
« Reply #4 on: March 16, 2007, 07:05:21 PM »
Let someone responsible know where you're going and the time you will be returning.  When you return to the ramp or slip, call to let them know you are back.
March 17, 2007, 06:51:09 AM
« Reply #5 on: March 17, 2007, 06:51:09 AM »
Quote from: "JimCt"
Alas - a "float plan". http://www.uscgboating.org/safety/fedreqs/floatplan.pdf
