Author Topic: Fuel Tank Grounding Help  (Read 6218 times)
February 23, 2007, 10:54:51 AM
Seadog
« Reply #15 on: February 23, 2007, 10:54:51 AM »
Boat Porn as requested. This gives you an idea of the progress.
In this shot you can see a piece of solid oak I used in the bow for the bow eye.  This will be the only wood used in the boat besides some mahogany trim around the console.  Resin doesn't penitrate into hardwoods like oak
very well so you have to make sure you have good bonds around the wood to hold it in place.
I left out the aft bulkhead in the fuel compartment to have better access glassing in the Kleg.  That will be added later.  Transom is 1.5" Coosa, stringers are 3/4" Kleg, floor will be 1/4" kelg.  Ran a piece of PVC tubing from the forward compartments, under the fuel tank to the aft bilge for drainage.  That was a major problem with these boats as they were originally designed - very poor drainage forward.
More shots soon as soon as I can figure out how to down load them off the new camera.
1970 Aquasport 222
Spring Hill, Fl.
February 23, 2007, 11:29:11 PM
« Reply #16 on: February 23, 2007, 11:29:11 PM »
absolutely amazing!that boat is going to be solid! :shock:
February 24, 2007, 05:07:29 AM
« Reply #17 on: February 24, 2007, 05:07:29 AM »
Lookin' great  :!:  :!:  Going on 2 years? Definitely a big project.  You probably don't want to ever see a grinder again  :lol:
Question: Is 1/4" going to be stout enough for the sole? If someone was to jump in from the dock, could it handle that?  I've heard stories where a person went that way because of the weigh savings and was very disappointed because of how flimsy it ended up being.
February 24, 2007, 07:15:31 AM
Seadog
« Reply #18 on: February 24, 2007, 07:15:31 AM »
Thanks Pete!
Rick - Be 3 years next month. I've heard those horror stories too. And to answer your question about 1/4" kleg being enough support: I'm not sure if it will be or not, but I think it will.
In the last picture above those cross members running to the side of the hull are about 15" apart.
The hard part is going to be filling the spaces with foam. The trick is to fill ALL the space with ONE single pour.  Lay in the floor and glass it in, drill the access holes, then pour way. If you have to do more than one pour to fill up the space there is going to be some air space created between the pours.  The air spaces will compress, probably fill up with water over time, and give less support.
I'm using FGCI's 2:1 epoxy throughout. 5:1 on the transom. On the floor the schedule is 5 layers of glass on each side - 3 layers of 17 oz DB and 2 layers of 17 RW.
No mat at all.
We'll she how she does.
Back to grounding the tank - Anybody know if the fuel fill should be wired to the fuel tank tab?
1970 Aquasport 222
Spring Hill, Fl.
February 24, 2007, 09:30:53 AM
JimCt
« Reply #19 on: February 24, 2007, 09:30:53 AM »
Not sure if it's really needed but I plan on grounding all elements of the fuel system. Not a big deal to do, just one wire from the filler to the tank tab.
Concerning a single pour for the foam, I found estimating the amount of A & B to achieve a certain volume of foam expansion isn't easy to do.  The info. sheet with the foam kit will tell you the expansion factor but a small variance measuring A & B can make a big difference in the final result.  I foamed my stringers in several stages and found with some care voids could be avoided.
Progress looks great!
JimCT
\'74 22-2 inboard
HIN:ASPL0953M74J
Chrysler 318
\'74 Marshall 22
February 28, 2007, 05:07:21 PM
PHILRAJOTTE
    • HTTP://WWW.ALLOYMETALWORKS.COM
« Reply #20 on: February 28, 2007, 05:07:21 PM »
one question where's the label for your tank, check this link for installing tank http://www.yachtsurvey.com/fueltank.htm
ALLOY METAL WORKS CUSTOM MARINE FUEL TANKS
631-694-8163  TOLL FREE 1-888-549-9353
March 01, 2007, 06:46:00 AM
Seadog
« Reply #21 on: March 01, 2007, 06:46:00 AM »
Tank doesn't have a label.
Is that important?
The current concensis on the tank installation link is that Pascoe probably
did not have a 22-2 in mind when he wrote it.  That recommendation is in
general for larger deep v vessels.
1970 Aquasport 222
Spring Hill, Fl.
March 01, 2007, 08:56:05 AM
PHILRAJOTTE
« Reply #22 on: March 01, 2007, 08:56:05 AM »
no label means tank is not cetified survoyer has to see it so you can get insurance
March 01, 2007, 09:01:02 AM
« Reply #23 on: March 01, 2007, 09:01:02 AM »
I do believe that they are right... you need a label on the tank for USCG reasons.  Not that anyone will ever stop you for that reason, but here ya go:
http://www.uscgboating.org/safety/boatbuilder/downloads/FUELSYSTEM.pdf
March 01, 2007, 12:13:36 PM
Seadog
« Reply #24 on: March 01, 2007, 12:13:36 PM »
No label - that pretty much sucks!
After you guys had me significantly freaked - I called the manufacturer -
they are making a label for this tank - should have it sometime next week.
THANKS FOR THE HELP!!!
Now got to go change my shorts...
1970 Aquasport 222
Spring Hill, Fl.
March 01, 2007, 12:58:31 PM
« Reply #25 on: March 01, 2007, 12:58:31 PM »
Sad thing is I have stumbled across a lot of "do and don't" guidelines, but wonder how much I am missing myself.  Get the boat assembled and run across some law/guideline I have missed.
March 01, 2007, 11:14:56 PM
« Reply #26 on: March 01, 2007, 11:14:56 PM »
Yes, the fuel fill should be grounded also.
March 02, 2007, 07:28:22 AM
JimCt
« Reply #27 on: March 02, 2007, 07:28:22 AM »
That USCG info. is interesting.  Glad I read it before starting anything to do with my fuel system.
Link should be made part of an on-line reference library section if we can put one together.
JimCT
\'74 22-2 inboard
HIN:ASPL0953M74J
Chrysler 318
\'74 Marshall 22
March 02, 2007, 07:51:38 AM
« Reply #28 on: March 02, 2007, 07:51:38 AM »
Quote from: "JimCt"
Someday...   :wink:
