165/170/175 Rebuilds
aquasport 17" 1970
Topic: aquasport 17" 1970 (Read 3263 times)
February 06, 2007, 10:45:27 PM
Read 3263 times
aqua70
aquasport 17" 1970
February 06, 2007, 10:45:27 PM »
Just joined !!!! I am going to need some help !!!
Aquasport 1970 17" I am trying to figure out how to post pictures.
Thanls RG
February 07, 2007, 05:31:32 AM
February 07, 2007, 05:31:32 AM »
Welcome aboard RG!! Another member of the 170 club 8)
Scale your pix to 640 x 480 and then upload them to the gallery. Then follow the directions in this thread
http://www.classicaquasport.com/forum/viewtopic.php?t=1042
February 07, 2007, 09:15:33 PM
aqua70
started today
February 07, 2007, 09:15:33 PM »
We started today! Stripping her down. Our first major encounter.. The plywood floor is somewhat soft. We drilled a few pilot holes, 2" wide to discover the plywood was water logged and semi rotted.
NEED SOME ADVICE<
Should we replace the plywood? The floor board has fiberglass on the top as well as the bottom.
If I email some pictures, can someone advice on where to cut and what to do ? Thanks RG
February 07, 2007, 09:25:09 PM
February 07, 2007, 09:25:09 PM »
The short answers are: yes and yes.
If you spend some time reviewing back through the AS Rebuilds section you will see several floor rebuilds. Two projects being done right now are LilRichard's and Shine's.
February 07, 2007, 09:36:29 PM
February 07, 2007, 09:36:29 PM »
This it?
February 07, 2007, 09:42:47 PM
aqua70
aqua 17
February 07, 2007, 09:42:47 PM »
That is it. How do I get the pictures from the photo gallery to the individual post? RG
February 07, 2007, 09:48:03 PM
aqua70
February 07, 2007, 09:48:03 PM »
kj
February 07, 2007, 09:52:15 PM
aqua70
February 07, 2007, 09:52:15 PM »
February 07, 2007, 09:59:47 PM
aqua70
February 07, 2007, 09:59:47 PM »
February 07, 2007, 09:59:55 PM
Reply #9 on:
February 07, 2007, 09:59:55 PM »
We've had some problems with the photo gallery on and off so I only use
www.photobucket.com
If you do want to post from the gallery, RickK put this up a while ago on how:
Go find the picture you want to use in a post and click on it so you see it in it's largest size. Now look down the page and the last line in the info below the pic is this line: "UBBCode: img]http://www.classicaquasport.com/gallery/data/......JPG[/img" (I purposely left off the starting [ before img and ending ] after the last img so you could see what is between them)
You highlight everything except the UBBCode: and paste it in your thread. It's that easy.
February 07, 2007, 10:01:40 PM
Reply #10 on:
February 07, 2007, 10:01:40 PM »
You beat me to it. Pictures are loud & clear now.
February 07, 2007, 10:04:32 PM
gw204
Reply #11 on:
February 07, 2007, 10:04:32 PM »
Did someone say rotten floor????
If it's solid in may places, you may not have to replace the entire thing. Drill a bunch of pilot holes to determine where bad ends and the good starts. Replace only what you need to if that's your thing. As for me, I like uniformity and knowing what I've got. Just the back 3' to 4' of the floor in my 170 is bad, but I'm doing the whole thing. Complete removal, new core, new bottom glass, new top glass, etc. I'm a glutton for punishment. :)
Brian
St. Leonard, MD
1981 Mako 17
1986 Grady White 227
February 07, 2007, 10:04:59 PM
Reply #12 on:
February 07, 2007, 10:04:59 PM »
I like those low rails. Those were an original option you rarely see.
February 08, 2007, 11:22:09 AM
Shine
Reply #13 on:
February 08, 2007, 11:22:09 AM »
It looks like you going to need a new transom, new sole (at least part of it), and probably new stringers (st least part of them).
The more you dig into the boat, the more yo will know
Hopefully the stingers will be in good shape and you will "just"need a new sole and transom.
Joel
February 08, 2007, 03:24:45 PM
aqua70
1970 aqua
Reply #14 on:
February 08, 2007, 03:24:45 PM »
removed the fiberglass covered plywood floor today. Pictures to follow later on. Question.. I thought the stringers would be solid wood. They seem to be molded foam, glassed into the hull bottom. Is this correct? When I replaced the floor in my Grady it was a series of 2x8's running the lenght of the boat.
The center beam on the Aqua seems to be a solid beam wrapped in foam and glass wrapped.
I have to clean her up and will take pictures. Any help would be appreciated. Thanks RG
aquasport 17" 1970
