Author Topic: 1997 Aquasport 175  (Read 134 times)
January 27, 2025, 08:36:10 AM
Read 134 times
jas300
1997 Aquasport 175
« on: January 27, 2025, 08:36:10 AM »
I have a 1997 Aquasport.
Had a Yamaha 90hp 2 stroke on it. I was getting air in the fuel system and it was sucking the primer ball shut.
Since then I’ve pulled the engine and sold it. Wondering if I should change the main fuel lines. I just bought a brand new merc 90hp 4 stroke for it.
January 27, 2025, 10:15:09 AM
dbiscayne
Re: 1997 Aquasport 175
« Reply #1 on: January 27, 2025, 10:15:09 AM »
Yes change the lines and the check valve at the tank pickup. Use good fuel line. If you ended up with the primer ball being sucked down that sounds more like a fuel line clog, not a leak letting air in.
A couple things to check, somewhere between the primer ball and the fuel tank the fuel line could have gotten so soft internally that it was collapsing as the pump is sucking fuel.
Or the check valve at the tank pickup has corroded, stuck partially closed and blocked flow.
I've experienced both of these and they showed up as the primer ball being squeezed down.
January 28, 2025, 12:40:00 PM
jas300
« Reply #2 on: January 28, 2025, 12:40:00 PM »
Appreciate the info. Looking forward to getting this on the water this summer! I’ll let you know how I make out
