Engines & engine woes
Repowering a 2005 osprey 175
Topic: Repowering a 2005 osprey 175 (Read 303 times)
January 25, 2025, 06:53:21 PM
Read 303 times
flounderbound
January 25, 2025, 06:53:21 PM »
My 2005 90 hp 2stroke Yamaha is on its last leg with bearing issues.I’d like to keep my 175 osprey and was told by Yamaha was that a90 hp 4stroke would be ok .The issue is that the 4stroke weighs about 100 lbs more than the 2stroke motor.I bought the Aquasport 175 new and it said maximum horsepower is 115..Was that 115 2 stroke or 4 stroke?
January 26, 2025, 02:27:25 PM
Re: Repowering a 2005 osprey 175
January 26, 2025, 02:27:25 PM »
I would think the hp is not the issue if the boat is rated for it but the extra weight may be. Did you like the 90 2stroke. I have always heard those motors make good rebuilds. Look at this build. It may have some answers
https://classicaquasport.com/smf/index.php?topic=10101.405
Rick is a wealthy knowledge and has a similar boat
January 26, 2025, 03:49:10 PM
January 26, 2025, 03:49:10 PM »
I agree with Duffy about rebuilding the 2 stroke. Not sure where you're located but see if you can locate a rebuilt powerhead place, not a mechanic to rebuild it. We have one such place in Tampa FL and that is where I purchased my rebuilt powerhead.
February 02, 2025, 05:20:31 PM
flounderbound
February 02, 2025, 05:20:31 PM »
I found the original Aquasport manual and it says the maximum weight allowed on a 175 osprey is 460 lbs. I think I`m going with the 90 4 stroke
