Author Topic: 1999 Aquasport 245 Rebuild  (Read 967 times)
March 20, 2025, 08:15:27 PM
rhtrades
Re: 1999 Aquasport 245 Rebuild
« Reply #15 on: March 20, 2025, 08:15:27 PM »
Well said and thank you for your reply, as always @RickK...ill let you know how I make out.
Thanks for all your efforts on this forum.
March 20, 2025, 10:39:57 PM
billy626
« Reply #16 on: March 20, 2025, 10:39:57 PM »
This is where I'm at with the boat... three layers of mat, tabbed in to the old floor. I didn't truly understand the gelcoat / expoxy discussion, but I have always applied gelcoat directly to hardened glass after using polyester resin... Never had an issue.
I will be working on that Cab-o-sil + gelcoat floor in the next two weeks. I'll let you know how it goes!
March 21, 2025, 12:30:37 PM
rhtrades
« Reply #17 on: March 21, 2025, 12:30:37 PM »
looks good @billy626... did you glass right over the older gelcoat edge or did you sand it down to the fiberglass?
March 21, 2025, 02:34:04 PM
billy626
« Reply #18 on: March 21, 2025, 02:34:04 PM »
@rhtrades Somewhere in between. I had to sand off all the nonskid, so it was sanded down quite a bit, but not all the way to the fiberglass. Didn't even think of that to be honest. Maybe would have been a good idea
April 20, 2025, 01:28:12 PM
billy626
« Reply #19 on: April 20, 2025, 01:28:12 PM »
Wrapping up this project, figured I would send a final update. After getting the deck glassed in, I spent a few hours sanding down the edges, as well as sanding off the rest of the non-skid on the bottom deck. (the back section that I didnt need to replace.) After everything was sanded, I added 4 layers of unwaxed gelcoat, followed by my last layer of waxed gelcoat with Cab-o-sil to give it that non-skid finish. This was my first time going that cab-o-sil route- came out decent. Wish I added a little more cab-o-sil to give even more grip, but overall came out good. (closeup picture below to see the finish) The new gelcoat is obviously a brighter white than the old, so I taped off a line just up the sides of the boat where the transition is. Happy with the final product overall - The sanding / gelcoat did a great job hiding the new layers of glass - cant see the transition at all. I wish I spent a little more time using hull and deck putty to blend the uneven spots where the deck pieces butt together (there's a few bumps here and there that if you are really looking you can see) but this deck should last me longer than I ever own this boat.
April 28, 2025, 11:04:18 PM
« Reply #20 on: April 28, 2025, 11:04:18 PM »
 :great02:
