Author Topic: Tach Rebuild?  (Read 389 times)
December 28, 2024, 01:43:03 PM
Read 389 times
Scode68
Tach Rebuild?
« on: December 28, 2024, 01:43:03 PM »
The tachometer on my 2001 215 DC is wonky, 200hp Johnson is the motor.  It doesn't read correctly all the time and when you tap on t it moves around a lot.
Any suggestions on a place to rebuild it?  I'm in New Jersey.
2001 Osprey 215 Sport
December 30, 2024, 09:00:33 AM
Scode68
Re: Tach Rebuild?
« Reply #1 on: December 30, 2024, 09:00:33 AM »
Or maybe I should try to find something new?
December 30, 2024, 11:42:06 AM
Re: Tach Rebuild?
« Reply #2 on: December 30, 2024, 11:42:06 AM »
I doubt you'll find a place to fix it. Might want to go to the teleflex site and see what they offer service-wise and look at new.
December 30, 2024, 01:58:35 PM
Scode68
Re: Tach Rebuild?
« Reply #3 on: December 30, 2024, 01:58:35 PM »
Dometic bought Seastar which bought Teleflex and I don't see any gauges on their site.
December 31, 2024, 02:11:20 PM
Re: Tach Rebuild?
« Reply #4 on: December 31, 2024, 02:11:20 PM »
Yeah, Dometic bought everything in the RV world to. Check Worst Marine, they probably stock them.
February 26, 2025, 07:53:14 PM
Scode68
Re: Tach Rebuild?
« Reply #5 on: February 26, 2025, 07:53:14 PM »
I finally pulled the tachometer out and have a few questions.
  • a 4” tachometer doesn’t necessarily fit in a 4” hole?
  • I can use any systems check tachometer with 8 pins if that’s what I have?
  • not looking for the most expensive but is Faria ok?
February 27, 2025, 06:11:31 AM
Re: Tach Rebuild?
« Reply #6 on: February 27, 2025, 06:11:31 AM »
Yup, I found out the same thing during my rebuild - a 2" gauge doesn't fit in a 2" hole - the same for a 4" gauge - needs a little bigger hole.
February 27, 2025, 06:34:43 AM
Scode68
Re: Tach Rebuild?
« Reply #7 on: February 27, 2025, 06:34:43 AM »
This gauge was so tight in the opening that I thought I was going to crack the cover plate.
February 27, 2025, 06:01:03 PM
01-Ospreysport215
Re: Tach Rebuild?
« Reply #8 on: February 27, 2025, 06:01:03 PM »
A standard size tach uses a 3-3/8” hole.
You can use any brand “system check” tachometer.
Faria are ok. I’ve seen many go bad over the years where the 4 lights work but the tach doesn’t read.
1990 Hydra-Sports 1750DC/2018 135HO E-tec
1995 Sunbird 200CC/2007 150 E-tec
2001 Osprey Sport 215/2013 300 E-tec
February 28, 2025, 02:36:10 PM
Scode68
Re: Tach Rebuild?
« Reply #9 on: February 28, 2025, 02:36:10 PM »
I’m not sure of what brand I have but it’s surely not original because it is a different color than the other gauges.  It’s a tight fit in there though and kind of works till you bounce around or tap it and it’s all over the place.
