Author Topic: Correct tool for cutting into Fiberglass Deck  (Read 608 times)
October 12, 2024, 10:58:50 AM
Read 608 times
rhtrades
« on: October 12, 2024, 10:58:50 AM »
Does anyone have a recommendation on the best cutting tool(s) and blades to cut into Fiberglass non-skid Deck?  (I am replacing my deck core).
Would an angle grinder work well?
October 12, 2024, 01:00:01 PM
Re: Correct tool for cutting into Fiberglass Deck
« Reply #1 on: October 12, 2024, 01:00:01 PM »
Most people use a skil saw and slide along the bottom of the liner. It leaves about 1.5-2" lip all around. Angle grinder will get the job done but you'll be all over the place with it.
October 14, 2024, 10:26:03 AM
rhtrades
« Reply #2 on: October 14, 2024, 10:26:03 AM »
Thanks Rick.  And would a metal cutting blade work well?    Also, do you have any recommendations on a brand of gel coat?
October 14, 2024, 12:02:18 PM
« Reply #3 on: October 14, 2024, 12:02:18 PM »
I don't know how a metal cutting blade would do. Any blade you cut fiberglass with is going to get trashed. The deck is mostly balsa wood with glass on both sides, so a wood cutting blade is what I used. I bought my gelcoat at a local supplier, it came in a white 5 gal pail. Not sure it had anything but their store name on it since they buy in bigger qty and break it down into smaller qty.
October 14, 2024, 01:57:28 PM
rhtrades
« Reply #4 on: October 14, 2024, 01:57:28 PM »
Thanks Rick.
October 18, 2024, 11:34:53 AM
msteinkampf
« Reply #5 on: October 18, 2024, 11:34:53 AM »
I tried a variety of oscillating blades, but none of them cut very effectively. I wound up using a 4.5 inch diamond blade for my angle grinder. Dewalt DW4701.  It’s marketed for cutting concrete. I cut out my entire deck, and it didn’t seem to dull the blade at all.
Expect a lot of dust.
m
1990 Boston Whaler Montauk 17 with 1991 Mercury 90 HP
1995 Aquasport Explorer 245 with twin 1995 Yamaha Salt Water Series 150 HP
October 22, 2024, 12:30:27 PM
rhtrades
« Reply #6 on: October 22, 2024, 12:30:27 PM »
Thanks M.  What thickness core did you use?
October 23, 2024, 08:49:39 AM
msteinkampf
« Reply #7 on: October 23, 2024, 08:49:39 AM »
This is from my deck rebuild thread, on which you have previously posted:
Quote
Although it’s hard to accurately measure the thickness of the old core material due to the water damage, it looks like it was nominal ¾-inch plywood, or about 23/32-inch thick.
I have much more detail about cutting and repairing the deck there: https://classicaquasport.com/smf/index.php?topic=16118.0
M
October 23, 2024, 09:17:51 AM
rhtrades
« Reply #8 on: October 23, 2024, 09:17:51 AM »
Thanks alot M!
October 23, 2024, 09:23:14 AM
rhtrades
« Reply #9 on: October 23, 2024, 09:23:14 AM »
believe it or not, i am having to replace the deck again.  The access hatch i put in a couple years back was not watertight and has caused  problems.  I am probably going to go with coosa this time.   I used a multi tool to cut into the deck last time around, but it took a long time and went thru alot blades, hence wondering if there is a better tool to use to cut fiberglass...
