Author Topic: Electrical Liquidtite instead of Trident/Dometic sanitation hose for floor drain  (Read 333 times)
August 27, 2024, 06:29:59 AM
Read 333 times
Hello all,
Call me crazy but I see no difference between the properties of the two products in the photos other than color and PRICE. I can get the electrical liquidtite for just over $3 a foot which is less than half price or more depending where you buy. Looking to use it for floor drains to thru hull plumbing. Anyone have any experiences? I will need quite a bit of it as I am adding two hatches with their own drains as well as the two aft in floor drains
August 27, 2024, 07:28:30 AM
Looks like the grey will do what you need. Make sure no one drinks out of the grey one though.
August 27, 2024, 08:57:40 AM
Thank you RickK. Just floor drains and definitely not potable. I have to drain 4 different in floor drains out of the boat so there is going to be a bit of plumbing which I have to figure out. I think West Marine was almost $20 a foot for the white stuff.
August 27, 2024, 02:41:10 PM
Confirmed…. $3.30 a foot by the foot at my local electrical supply. Cha chingggg!!
September 23, 2024, 02:24:23 AM
Well damnnnn. Too good to be true. So the inside diameter from the websites state 1.56 to 1.6 which worked fine for a 1.5” plastic barbed fitting but was too big for a smooth walled bronze 1.5” OD drains that I am using. The marine supply stuff is a true 1.5 or close to it. I had to go with the $8 a foot stuff. I felt to clamp it down that much might put undue pressure on the hose and create a weak spot. Don’t know for sure but it didn’t feel right to me. So it could work just depends on what you are connecting it to. I’m going all bronze.
