Author Topic: 1995 Evinrude 88HP - Muffs vs Water Running Issues  (Read 186 times)
August 05, 2024, 02:43:29 PM
Read 186 times
LG Osprey
« on: August 05, 2024, 02:43:29 PM »
The 1995 Evinrude 88HP that is on my 95 Osprey 17.5 is having a strange problem.
Engine starts up beautifully on muffs, no issues running at idle on muffs up to operating temp. However the minute the boat is launched and in the water at the ramp, thing idles terribly. Have to keep revs high to keep it from dying and the minute you get close to idle speed to put her in gear it dies.
Here are some supporting facts:
-all cylinders pass compression test no problem
-all spark plugs are gapped correctly
-fresh fuel and fuel/water separator
-has not been actively run since 2022 season
Some research online via MarineEngine etc. would lead me to believe its either a spark/misfire issue, a carb float issue, or potentially something with the anti-siphon?
Let me know any and all thoughts on this one... thanks!
August 06, 2024, 03:58:13 PM
dbiscayne
Re: 1995 Evinrude 88HP - Muffs vs Water Running Issues
« Reply #1 on: August 06, 2024, 03:58:13 PM »
Sounds like a carb issue might be time for a good cleaning, they're pretty simple to do. Once its in the water the exhaust sees a lot more backpressure vs. being on the hose, changes the way it idles for sure.
Can you rig up a test tank to run it at home? Really big trash can, don't need to spin the prop.
