Congrats, I am sure it will bring the desired step up from the 170. 8) 8)
jd, congrats on the new boat, u and i talked about my boat but i've been busy and storage is already paid and i've been so busy, but looks like u SCORED! A few suggestions that u had questions about, 1st being interior glass polishing. I'm not anti-compund by any means, but i would try something slightly less "nuke"(for lack of a better word)to get some gloss back to the interior, or exterior for that matter. I would give 3M color restorer a try before even the gentlest compound. I also like the result by hand if u have the time, literally the harder u rub, the brighter the surface gets. I used to detail for a living and a wheel was always used, but to much room for error even in trusted hands. For example whether a car or boat when waxing, glazing, compounding when i said the harder u rub the brighter it gets, there is a point of "diminishing returns". U want to rub or buff hard enough to actually heat up a given area, but there is a temperature that car paint, boat paint/gelcoat etc. will be damaged rather than polished. A wheel in inexperienced hands can behead a perfectionist. By hand gives u an actual feeling on your fingertips. Any 3M product isn't cheap but a far superior product and the "color restorer" i highly recommend as a 1st option. With regards to a missing splash door i think u said it was teak or mohagany, i strongly suggest starboard or seaboard. I prefer the look of a finely finished piece of functional boat wood myself, but found little time given other projects. Given the function splash doors serve a star/sea board replacement will look great and need no maintenance for 30 years. Good luck and share some pics[/quoteThanks for the congrats and the info I actually worked a little on the inside yesterday afternoon. I tried 3m rubbing compund and it worked wonders on the inside. It removed all of the oxidation and brought back some of the shine. I did that by hand and it came out great. I know JimCt had suggested rubbing compound and that what I was leaning toward to try. I might go ahead and go over that with the 3m color restorer and see what we got As far as the splash well door goes, I agree with you. This boat has enough teak that needs to be refinished and I hate to add anymore. Went to Boaters World last night and they have boards made by TACO that I have heard are excellent to make hatches and so forth out of. I think it is the same stuff that you are talking about. They are already finished and all you have to do is cut & fit. They look really good so I plan to replace the hatches on the stern with the same thing. Hope to get some pictures posted this weekend. Thanks :)
Hey John,i used the 3m marine color restorer/compound/wax stuff on the sides and used a buffer and it came out like a new penny..unfortunatly that was about 4 mo. prior to your coming up but it works great and makes it smooth as a baby's butt
