Author Topic: Osprey 175 Fuel Sender Length  (Read 208 times)
May 04, 2024, 05:36:41 PM
Read 208 times
RSB
« on: May 04, 2024, 05:36:41 PM »
What is the length of the fuel tank sender on a 2000 175 Center Console?
Richard
2000 Aquasport 175
1989 Blackfin 29 FB
Grumman 1436 Jonboat
May 06, 2024, 10:52:32 AM
Re: Osprey 175 Fuel Sender Length
« Reply #1 on: May 06, 2024, 10:52:32 AM »
We see this pop up from time to time and the stock answer is; "pull the sender and measure". Most members asking because they would like to have the sender on hand when they replace. Understood but....
Since different size tanks (depth) were used on different models, it's often unknown which size fits what models so .....
Here is a model that may be somewhat like yours: :ScrChin:
https://www.moellermarine.com/moeller-marine/fuel-accessories/fuel-senders-gauges/electric/electric-sending-unit-for-4-28-inch-complete-kit-with-fuel-gauge-035726-10/
It's adjustable to different depth tanks.
I retrieve the model # from this thread (see below), which is for a hull model that is somewhat like what you have.
https://classicaquasport.com/smf/index.php?topic=15314.msg149739#msg149739
If you want to update your mechanical sender, you may be interested in a "reed type" like this but you would again be best suited to measure first if you decide to install this type.
https://www.amazon.com/Moeller-Marine-Electrical-Sending-Complete/dp/B07JX8DWPT
Lastly, mounting hole alignment needs to be considered. While, for the most part, these are standardized, checking never hurts.
May 08, 2024, 12:32:00 PM
RSB
« Reply #2 on: May 08, 2024, 12:32:00 PM »
Much appreciated. I’ll pull it and dip the tank. I will definitely go with the Reed style. I just replaced three on my Blackfin 29. Superior product. It will be the first time all 3 gauges are working at the same time.
Richard
2000 Aquasport 175
1989 Blackfin 29 FB
May 08, 2024, 03:09:34 PM
« Reply #3 on: May 08, 2024, 03:09:34 PM »
Report back with what you purchased and how long it was so someone else can have that info. Thanks
May 11, 2024, 08:09:45 AM
RSB
« Reply #4 on: May 11, 2024, 08:09:45 AM »
I will get to the boat and measure. (It may take a couple of weeks to find the time)
Richard
2000 Aquasport 175
1989 Blackfin 29 FB
