196 Rebuilds
1973 196 rebuild question
43
44
Topic: 1973 196 rebuild question (Read 24553 times)
May 01, 2025, 06:33:58 PM
Reply #645
Re: 1973 196 rebuild question
Reply #645 on:
May 01, 2025, 06:33:58 PM »
This method works but the bubbles in the gutter are difficult to avoid. I end up grinding most of them out and filling them with thickened resin. I will put another layer or 2 of 1708 from the bottom for additional gutter strength
May 02, 2025, 07:40:41 AM
Reply #646
Reply #646 on:
May 02, 2025, 07:40:41 AM »
I am selecting wire to run from console to bow for a trolling motor, roughly 10 feet (70 or 80 lbs minn kota) and for starter wires for my outboard, also about 10 feet plus with turns and what not, which is a 115 yamaha 4 stroke. I researched that minn Kota recommends 8 gauge for the trolling motor application. I suspect 6 gauge is what the yammy needs. Can I use 6 gauge for both? Bigger wire is okay and smaller wire is not? I was going to purchase kambluth marine tinned duplex wire.
I wired plenty of boats and made it work but always fresh water boats with easy wire run access. I want to rig this boat right because it is not easy access and is going to be a salt water boat. HELP and thanks for any input.
May 02, 2025, 04:20:25 PM
Reply #647
Reply #647 on:
May 02, 2025, 04:20:25 PM »
I used 2AWG for the trolling motor. Batts are in the console. Then I'll use the trolling motor leads from the terminals I installed. I used 2/0 for the starting battery cable.
https://classicaquasport.com/smf/index.php?topic=10101.msg135125#msg135125
May 03, 2025, 06:07:51 PM
Reply #648
Reply #648 on:
May 03, 2025, 06:07:51 PM »
Thank you rick
May 04, 2025, 08:44:25 AM
Reply #649
Reply #649 on:
May 04, 2025, 08:44:25 AM »
Bilge hatch is next. Below process was as follows:
1. Put layer of Matt and thickened resin around bilge deck cut out
2. Insert gutter assembly into deck cut out
3. Wait for glass to cure then grind
4. Reglass areas of poor contact
5. Flip over and glass gutter assembly from bottom for additional strength
May 04, 2025, 08:03:22 PM
Reply #650
Reply #650 on:
May 04, 2025, 08:03:22 PM »
looking good
May 05, 2025, 07:40:56 AM
Reply #651
Reply #651 on:
May 05, 2025, 07:40:56 AM »
Thank you Rick.. here are some hatch pictures. Beveled the core this time. This I ne 8s matte x 2 then lhen 1708, core, matte, 1708, plastic, and finally battery
May 05, 2025, 11:16:14 AM
Reply #652
Reply #652 on:
May 05, 2025, 11:16:14 AM »
Looking really good Duffy. I was getting worried cause a few weeks went by without updates but clearly your moving right along! Great work!
74'-240 -
68'- 222 -
70’- 222-
81’-222 -
72'-240 - SOLD
71'-222 - SOLD
May 05, 2025, 02:38:46 PM
Reply #653
Reply #653 on:
May 05, 2025, 02:38:46 PM »
Had a 25th wedding anniversary. Was out of town for 10 days or so. Appreciate the concerm. Yeah, the Mrs deserved a trip for putting up with me for so long. Told her she gets 25 to life more.
At any rate I made the hatch 1 inch too long. So stupid. Going to try hinging it in the middle or making a two part hatch or cutting in half and lamming back together. Again, soooooo stupid. Any advice other than measure twice cut once?
May 05, 2025, 10:20:14 PM
Reply #654
Reply #654 on:
May 05, 2025, 10:20:14 PM »
Cut the hatch in half. It fits now. I suppose I will glass it back together. Will probably not do the piano hinge in the middle. Included some other pics of front hatch.
May 06, 2025, 08:05:22 PM
Reply #655
Reply #655 on:
May 06, 2025, 08:05:22 PM »
Lammed the bottom of the hatch with extra piece of divinycell. Will put a sheet of matte on other side .
43
44
196 Rebuilds
