196 Rebuilds
1973 196 rebuild question
31
32
Topic: 1973 196 rebuild question (Read 12785 times)
December 07, 2024, 04:12:57 PM
Reply #465
Re: 1973 196 rebuild question
Reply #465 on:
December 07, 2024, 04:12:57 PM »
Also glassed 2 layers 1708 and layer of Matt on starboard deck section.
December 11, 2024, 06:29:33 PM
Reply #466
Reply #466 on:
December 11, 2024, 06:29:33 PM »
2 layers 1708 9n other side of deck piece. Will get pics after it cures
December 15, 2024, 10:27:36 PM
Reply #467
Reply #467 on:
December 15, 2024, 10:27:36 PM »
Dragging my feet on glassing in rigging tubes. They are about where I want them. Pushed some test cables through them. All good for that..
December 17, 2024, 02:57:01 PM
Reply #468
Reply #468 on:
December 17, 2024, 02:57:01 PM »
Really ugly glass job but hopefully I will never see it again. Rigging tunes installed for better or worse.
December 18, 2024, 11:45:01 AM
Reply #469
Reply #469 on:
December 18, 2024, 11:45:01 AM »
So, how many drain holes in each rigging tube does the community recommend? They obviously need to be in the lowest spot, but after that I am at loss for the number of holes. Right now I have 2 holes In each tube at the 45 degree tu=n.
December 18, 2024, 11:51:53 AM
Reply #470
dbiscayne
Reply #470 on:
December 18, 2024, 11:51:53 AM »
I poured 2lb foam under my deck between the stringers except against the transom where the tubes were. Added about a 1/4" hole at the very back/rear end of the tubes just before they bend up, this was the only area not foamed under the deck where my tubes ran. Have a 1" drain at the bottom of the stringer against the transom connecting the cavity to the bilge. Just made sure I sealed the rigging tubes real good where the wiring exited so hopefully I don't get any water in there.
December 18, 2024, 06:52:39 PM
Reply #471
Reply #471 on:
December 18, 2024, 06:52:39 PM »
Roger that. Perhaps I will just seal them extra good.
December 20, 2024, 07:14:12 PM
Reply #472
Reply #472 on:
December 20, 2024, 07:14:12 PM »
Glassing the center section of the deck. layer of 1708 and layer of mat on the top.. Should I do 2 layers of 1708 I n bottom?
Today
at 06:18:30 AM
Reply #473
Reply #473 on:
Today
at 06:18:30 AM »
2 layers on the bottom will stiffen up the whole thing
31
32
196 Rebuilds
