Author Topic: 1973 196 rebuild question  (Read 12787 times)
December 07, 2024, 04:12:57 PM
Reply #465
Re: 1973 196 rebuild question
« Reply #465 on: December 07, 2024, 04:12:57 PM »
Also glassed 2 layers 1708 and layer of Matt on starboard deck section.
December 11, 2024, 06:29:33 PM
Reply #466
« Reply #466 on: December 11, 2024, 06:29:33 PM »
2 layers 1708 9n other side of deck piece. Will get pics after it cures
December 15, 2024, 10:27:36 PM
Reply #467
« Reply #467 on: December 15, 2024, 10:27:36 PM »
Dragging my feet on glassing in rigging tubes. They are about where I want them. Pushed some test cables through them. All good for that..
December 17, 2024, 02:57:01 PM
Reply #468
« Reply #468 on: December 17, 2024, 02:57:01 PM »
Really ugly glass job but hopefully I will never see it again.  Rigging tunes installed for better or worse.
December 18, 2024, 11:45:01 AM
Reply #469
« Reply #469 on: December 18, 2024, 11:45:01 AM »
So, how many drain holes in each rigging tube does the community recommend? They obviously need to be in the lowest spot, but after that I am at loss for the number of holes. Right now I have 2 holes In each tube at the 45 degree tu=n.
December 18, 2024, 11:51:53 AM
Reply #470
dbiscayne
« Reply #470 on: December 18, 2024, 11:51:53 AM »
I poured 2lb foam under my deck between the stringers except against the transom where the tubes were. Added about a 1/4" hole at the very back/rear end of the tubes just before they bend up, this was the only area not foamed under the deck where my tubes ran. Have a 1" drain at the bottom of the stringer against the transom connecting the cavity to the bilge. Just made sure I sealed the rigging tubes real good where the wiring exited so hopefully I don't get any water in there.
December 18, 2024, 06:52:39 PM
Reply #471
« Reply #471 on: December 18, 2024, 06:52:39 PM »
Roger that. Perhaps I will just seal them extra good.
December 20, 2024, 07:14:12 PM
Reply #472
« Reply #472 on: December 20, 2024, 07:14:12 PM »
Glassing the center section of the deck. layer of 1708 and layer of mat on the top.. Should I do 2 layers of 1708 I n bottom?
Today at 06:18:30 AM
Reply #473
« Reply #473 on: Today at 06:18:30 AM »
2 layers on the bottom will stiffen up the whole thing
